2008 tC with a rough idle
Old May 17, 2009 | 09:29 PM
draxxus0321's Avatar
Music City Scions
Default 2008 tC with a rough idle
I have a 2008 Scion tC. about a week ago it started to idle real rough. Its so rough it actually rattle my exhaust. I also have real bad valve chatter.
Anyone have any ideas about what could be wrong? Mods done to the motor are:
HPS short ram intake
Alpha Werks Header
Megan racing mid-pipe
Skunk2 Cat-Back exhaust
Greddy Emanage Blue
If anyone has any ideas please help me out. I hate my baby running like this.
Old May 17, 2009 | 10:21 PM
elcapetan's Avatar
bent valves? have you miss shifted?
Old May 17, 2009 | 10:30 PM
SW_08's Avatar
idk but it might be something that you can see physically too....ummm check your vacuum hoses for splits
Old May 17, 2009 | 11:31 PM
Socal_Shara's Avatar
mmm I have the same too. Almost sounds like a chattery motor mount, but when i popped my hood to check it sounds like its coming from the valve train. It dose not do it all the time which is weird because i figured if it were the valves it would do it all the time right?
Old May 18, 2009 | 01:53 AM
cburglb34's Avatar
i have the same problem, ive also notice if my car is uphill it makes the noise but downhill it doesnt, my car like to idle rough every couple of months and when driving itll bog but i figure its my maf sensor going bad so i always just reset ecu and im good to go =]......GHETTO WAY AT FIXING A PROBLEM=WIN
Old May 18, 2009 | 02:02 AM
BZinn1's Avatar
ok stupid question but why are you using the Emanage blue........and the 08 computer I thought relearns its tune if you change it........not sure 100% onthat but it is possible.
check your vacume lines and your EGR valve on the back of the valve cover,it may be loose..........
other than that toyotas have noisy valve tranes......and if you have AC on it will shake a bit and get louder.
could also be you damaged the MAF installing the CAI.......coupler loose on the CAI,man there are a lot of things that could be wrong.
Old May 18, 2009 | 02:06 AM
cburglb34's Avatar
yea the other day i tigthemed my egr and my brake booster line because thats where my vacuum block is taped into and it fixed my problems....as far as noise...its not the usual valve train chik chik chik its a chik chik chik..click chik click click chik its kind alike a beat...but then when given more rpms is dissapears and also ac being on eliminates the noise
Old May 18, 2009 | 03:14 AM
mine is a actual chatter from what sounds like my exhaust valves. I'm going to take off the header and see if anythings bent this week. The chatter comes and goes at idle in 5-10 sec incraments off and on. I wish i member the post but another had some bent valves and was hearing a clicking sound. I have 16k miles on my motor thou
Old May 18, 2009 | 03:19 AM
firesquare's Avatar
you gotta take out that huge stage 3 cam you got.
i notice in camry's the motor is very shaky. check your oil. maybe next oil change throw in a qt of lucas?
Old May 18, 2009 | 03:26 AM
idk, The timing was checked before the car was started and it ran fine and quite till now. It almost sounds like a belt chatter but its coming from my exhaust manifold. And you can hear it from outside of the car with the hood closed. I hate driving around and my car squeaking at red lights. lol When i pop the header off i'll know for sure
Old May 18, 2009 | 03:42 AM
dorijoon's Avatar
i'm actually having the same problem as the OP.
its been like over 4 months or so since i've noticed the rough idle.
i didn't think to much about it, but after scanning the forums.
i thought i should ask for some help.
i have similar mods as the OP.
Injen CAI
Alphawerks Header
Full Skunk2 Exhaust w/ a 24in Magnaflow Resonator
i'm thinking about reseting the ECU.
any thoughts?
Old May 18, 2009 | 04:31 AM
BZinn1's Avatar
yeah check al the things I listed as they seem to be the most comman causes for shaking idle.
bent valves could be cause of chatter,even worn cam could do it,timing chain stretched......cars are a pain at times.....lol
o2 sensor on the header could be wearing out or damaged too......that is a spendy pain there.
Old May 18, 2009 | 06:51 AM
dorijoon's Avatar
well i'm using an automatic trans.
and i've only had the for about 22k miles.
so i don't think worn cams, timing belt, and valves could be the problem
lol, even if they were i don't even know how to get to those parts on my car.
my o2 sensor was replaced like a month ago, i bought it from someone from SL.
so, i doubt thats the issue too. lol, maybe i'm a little to trusting in used parts?
i did get T-Boned sometime in November.
maybe its a faulty motor mount?
who knows i should get my mechanic to take a look at it.
Old May 18, 2009 | 02:56 PM
BZinn1's Avatar
check the o2 sensor and make sure it is not loose,also could be a motor mount......
mischman
Sep 15, 2015 03:38 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
rancur3p1c
Jul 12, 2015 07:59 PM
TinmanTC
Jul 12, 2015 07:53 PM
SFXB
Jul 9, 2015 11:00 PM
