RealCamber.com camber plate instal.
Old Jul 1, 2009 | 01:37 AM
BlueJDMBoxV2's Avatar
Default RealCamber.com camber plate instal.
1st off you do this at your own risk, these camber plates are "said" off road only.
this is going to be a quick step guide with just the right amount of info to install them yourself
If you have a jack and simple tools, this is as easy as riding a bike.
tools needed: 10mm, 17mm sockets, anti-corroding compound, metal file, flathead, and that stuff that helps you remove rusted bolts.
the shims, and bolts the shims are -3's but install would be the same if you got the -5's.
back plate this go's on the back before the bolts, note the countersinking, this is so the bolts will line up right with the camber on the other side of where the hub bolts up.Name:  DSC_0033-1.jpg
this is the camber shim itself, note the stamp on the top, this indicates what side it go's on make sure its at the top and facing you when you put it on, the shim go's on the other side of where the backer plate go's ( if you have hub spacers the camber plate go's on 1st then the hub spacer the the hub it self )
the other bolts you will need to take off other then the 4 on each side that hold the hub on
the clamp that its attached to the e-brake line will nee to be moved up on the line, due to the hub being pushed out and away. you should be abale to do this with a flat head.
let the next two photos show you whey you use anti-corroding compound. its so bad that my spacer shims are stuck the the hubs.
every thing bolted back on up, 10mm above the hub, then the -3 camber shim then the hub support, then the backer plate, make sure you set the bolts to factory spec.
before
after
close up of the camber
pic of side of car
Old Jul 1, 2009 | 04:03 AM
swartzautoman's Avatar
now you can go lower!
good write up
ive got a 1/2 hub spacer and -3 camber in thr rear myself, i love it, its so sexy
Old Jul 1, 2009 | 04:52 PM
i still have to do the fronts, picking up the cosco camber plates and then the spc bolts to get -3 up front then drop in the bolts in the back for -4
Old Jul 2, 2009 | 01:23 AM
kewlbox's Avatar
I like the use of the phil wood grease.
Old Jul 2, 2009 | 04:39 AM
yeah i used that on the wheel studs, they were mighty rusty.
Old Oct 22, 2012 | 08:13 PM
NO_BOX_NO's Avatar
and if you sheer off multiple bolts on the hub assembly...?
Old Jan 20, 2013 | 10:11 PM
hmc2261CT's Avatar
Not really sure why you would do this, I know it can look good like when a car is on bags and all the way down, but in my honest opinion if your driving like this all the time it just causes headaches. Uneven tire wear, more stress on the axel and more stress on the bearings.
Just my opinion.
Darrenohooligan
Sep 26, 2015 07:21 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Subaru86
Sep 14, 2015 12:43 PM
domincnTC
Aug 4, 2015 01:47 PM
Subaru86
Jul 31, 2015 04:33 AM
