Auto XB AEM intake rattle
Old Jan 26, 2004 | 03:21 PM
Cameron's Avatar
Default Auto XB AEM intake rattle
After installing my AEM intake, I've noticed a rattle at stop lights. I've deduced this will be only evident on Automatics with the AEM intake.
The AEM attaches to the transmission with one bolt. In Drive gear, at full brake, the transmission vibrates at a different rate than the engine. If clearances are not just perfect with the AEM intake, a faint rattle may sound as the intake shakes at a different frequency than the engine.
I've made a few adjustments, now the rattle is only very very faint (I'm the only one who notices). Has anyone else experienced this? Is there a sure-fire solution?
Old Jan 26, 2004 | 03:39 PM
izzles's Avatar
I have found thats its where the sensor is at near the valve cover I have cut that extra part on the intake to where that sensor sits and let it hang you will find that it doesnt vibrate reallt much after that.....
Old Jan 26, 2004 | 09:44 PM
Cameron's Avatar
I'll try it, but I don't think that's it. I already got the VCV electrically taped to the intake extension where the VCV is supposed to "clip" on.
Thank you tho.
Old Jan 26, 2004 | 10:02 PM
showpaojoe's Avatar
IV ACE
same problem on my manual. when i slow down or stop. goin 2 months strong now
Old Jan 26, 2004 | 10:34 PM
Djuan's Avatar
Default good ?
I'm glad you guys mentioned that I was thinking of getting an AEM intake... Do all the intakes rattle ?
Old Jan 26, 2004 | 11:37 PM
proto_k7's Avatar
My blitz rattles at the valve cover-
Old Jan 26, 2004 | 11:44 PM
scionaraxb's Avatar
No rattles here..AEM w/ auto.
Old Feb 2, 2004 | 03:21 PM
Cameron's Avatar
Rattle source found.
The AEM filter element was vibrating against the back of the FOG LIGHTS. I just shifted the filter around and the rattle stopped.
I may anchor the filter away from this area using zip ties or silence it with a thin strip of foam rubber and some tape.
The connection of the filter to the intake pipe is rubber, so I may even be able to angle the filter away from the back of the light.
Scionaraxb, do you have fog lights on your car? Just wondering.
Old Feb 2, 2004 | 03:38 PM
George's Avatar
This is a common problem with the AEM intake.
Also, check under the intake pipe to make sure that it isn't contacting the air bag sensor on the "frame rail". I saw one that had almost worn a hole through the intake!
George
Old Feb 2, 2004 | 04:07 PM
EcksBee's Avatar
your first problem is that you bought the AEM intake..sell that back to toyota and get an Injen.. It is bad ___....
Old Feb 2, 2004 | 04:27 PM
squirrel's Avatar
my Injen intake doesn't seem to make any rattling noises.
Old Feb 2, 2004 | 04:43 PM
Cameron's Avatar
Just trying to help those with an AEM intake that does rattle, thanx
Old Feb 2, 2004 | 06:46 PM
Djuan's Avatar
Default it could happen
rattle source found
Solowcal_tc1
14
Feb 27, 2024 06:23 PM
Wide_tC
Jan 15, 2004 01:00 PM
obz
28
Dec 11, 2003 06:27 PM
Besk_one
12
Nov 17, 2003 10:29 PM
yanges
16
Sep 26, 2003 06:01 PM
