Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Suspension & Handling
Register Forgot Password?
Reply
Old 07-08-2009, 03:44 AM   #1
Sciontized
Sciontized 34/M
Default oem brake help
for some time now on my '06 TC, I question the dealer saying that my brakes are fine, but i have this problem. Whenever i park on a hill or even a slightly slanted hill and use my e-brake, my brakes make a grinding noise and my car abrubtly rolls a little. The noise sounds like if you have the e-brake up and try to start rolling, it makes that grinding noise. This happen about a year and a half after i bought the car brand new. Any ideas?
Sciontized is offline   Reply With Quote
Old 07-08-2009, 04:32 AM   #2
06scionbhs
06scionbhs 22/M
hmm id say check your pads? make sure there is good life on em...but a lot of the time a grinding sound is because of the rotors. may be worn out time for some new ones?
Is that part of my car? or yours?
06scionbhs is offline   Reply With Quote
Old 07-08-2009, 09:41 AM   #3
sciontc_mich
sciontc_mich 113/M
Default Re: oem brake help
Quote:
sounds like your e-brake isn't adjusted tight enough for the 6-9 clicks when you pull up on it for it to stop the car from rolling. The e-brake at the rear brakes needs to have 1-3 more clicks applied to them from where they are adjusted now.
But the safest is to do a search on how to adjust them, do NOT adjust the e-brake at the handle, ALWAYS adjust it at the rear brakes.
Dealer obviously is being lazy giving you the old tired line of "it's okay"..
sciontc_mich is offline   Reply With Quote
Old 07-15-2009, 03:45 AM   #4
07_Tc_blacksandpearl
07_Tc_blacksandpearl's Avatar
07_Tc_blacksandpearl 24/M
Send a message via AIM to 07_Tc_blacksandpearl
Quote:
Not bashing you but pads and rotors have nothing to do with the e-brake. The e-brake style for tc's are drum in hat, which means there is a small drum brake inside the hat of the rotor, that is there strictly for the parking brake. You should do major adjustments at the assembly itself (I believe the rotors have to be removed) but fine tuning can be done at the e-brake handle. ( I dont know if you can adjust the e-brake at the handle of the tc or not, to be honest). If you need help adjusting the e-brake and the dealer refuses to do it unless you pay, pm me and I'll see if I can't help you out.
07_Tc_blacksandpearl is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
