VSC, ABS, and TRAC CNTRL lights on?
Old Jan 29, 2005 | 01:29 AM
randode's Avatar
Wagonistas
Default VSC, ABS, and TRAC CNTRL lights on?
so, i start my xB the other day and the VSC, ABS, and TRACTION CONTROL lights came on. I turned the car off, then back on and they stayed off. This has happened 3 times since then. WTF? I really dont want to take the car to a dealer (dont get me started).
Old Jan 29, 2005 | 06:58 AM
smokyXB's Avatar
did you mess arround with wheel shims?
Old Jan 30, 2005 | 03:53 AM
randode's Avatar
Wagonistas
i didnt do anything. they just started coming on.
Old Jan 30, 2005 | 03:59 AM
squirrel's Avatar
Hmm, I have no idea and haven't heard of that. The fuse maybe?
Old Jan 30, 2005 | 04:12 PM
randode's Avatar
Wagonistas
nope. and if i turn the car off, then back on, its fine.
Old Jan 30, 2005 | 04:18 PM
dgHotLava's Avatar
i had that once...
ran the car for 10mins around town. turned off the car, let it sit while i poked around under the hood. restarted the car after a few mins and they were gone....
can't say what it was or how it went away...
Old Jan 30, 2005 | 06:40 PM
lastlookcustoms's Avatar
Mine are on with my check engine light because of my intake. At least thats what I have been told by the dealer... I keep throwing a code for too lean.
Old Jan 31, 2005 | 12:49 AM
sciontificxb's Avatar
i had the same problem. I bought my xb wrecked and it was hit on the front dirvers side, to fix the problem i had to replace a wheel speed sensor.
Old Jan 31, 2005 | 02:40 AM
MotoMan_YZ400's Avatar
check gas cap.... if it;s loose or cross threaded it will do that.... i had an intake do that, but it stayed on..... hey w/ your Trac control off.... time for some mad Ebrake turns jk
Old Jan 31, 2005 | 03:59 AM
TheScionicMan's Avatar
Maybe reset the ecu?
Old Jan 31, 2005 | 04:55 AM
Buebie's Avatar
MN Scions
Yea, I'd say reset the ECU. Thats sounds wack...you running factory sway bars? Cause I had to take my front Hotchkis out because I was experiencing what you are...except my engine was sputtering. So on the bright side, at least your engine isnt sputtering and the VSC isnt coming on at 50mph on a straight flat road.
That or a wire might be kinked, or bent. Might want to check and see if the boots are clear of any twigs and or road debris. Those wheel sensors around the boots are a pain.
Old Jan 31, 2005 | 05:15 AM
UnFocused's Avatar
I believe that there is a TSB out for this- has something to do with the engine knock sensor-
the website that I know of that lists them is down at the moment....
Old Jan 31, 2005 | 05:40 AM
Default Re: VSC, ABS, and TRAC CNTRL lights on?
Randode, this happened to me when the air sensor got dirty. All the lights came on and stayed on until I turned off teh car and restarted it. The dealership cleaned the air sensor and reset the codes. Basicly sprayed it with carb cleaner and reset the computer. Tey that and see what happens. :D I hope this helps.
Old Jan 31, 2005 | 03:14 PM
randode's Avatar
Wagonistas
you mean the MAF sensor in the intake?
Old Jan 31, 2005 | 03:47 PM
az_pinoy's Avatar
it's those damn cathode lights
JC
Old Jan 31, 2005 | 04:09 PM
Yeah, the MAF sensor. They basicly took it out and cleaned it off. It got dirty because I was experimenting with intakes. (Never again) :D
Old Jan 31, 2005 | 04:15 PM
erichlf's Avatar
Same thing with me, but those lights come on for so many different reasons. After having my MAF cleaned they have not come back on for about 2k miles. The mechanic at the dealership said it would continue to happen and would eventually ruin my MAF. But, I think it only happened, because I didn't follow the instruction to the T and clean the pipe before install, thus leaving dirt and stuff in there making the MAF get dirty.
Old Jan 31, 2005 | 04:17 PM
They told you it would come back? Mine hasn't come back since then. I wonder why they said that?
Old Jan 31, 2005 | 04:28 PM
dgHotLava's Avatar
thats why mine went on...couldn't think of what i was doing....
i took off the intake pipes so i could put in a new upper rad hose. nothing should have caused this to happen. i did think the Mass Air Flow sensor had dirt on it....
Old Jan 31, 2005 | 04:39 PM
There you go, glad I could help out. Randode check it out. :D
