problems with Tein Ss
Old Jan 29, 2005 | 06:13 PM
metalranger33's Avatar
Default problems with Tein Ss
since in in stalled them ive been getting a popping sound when i turn my wheel is this normal, do i need to do somthing
Old Jan 29, 2005 | 06:40 PM
adamstc's Avatar
thats not normal, you left something lose or something, do you have rims or stock, maybe if you have the wrong offset and its now rubing, but unlikely,
Old Jan 29, 2005 | 07:51 PM
ScionTCTrav's Avatar
Did you forget to install one of the springs *haha* JK
Old Jan 29, 2005 | 09:19 PM
daewonder's Avatar
that's not normal. if you did it yourself, i'd say take it apart and reinstall making sure to double-check everything. if you had a shop install them, take it back and tell them of the problem.
Old Jan 29, 2005 | 10:46 PM
MrChoyBoi's Avatar
Nothing major, I would go with daewonder's advice if it was installed by yourself. The springs could have been installed backwards which would cause that popping sound.
Good luck!
Old Jan 30, 2005 | 05:46 AM
Otocan's Avatar
the popping sound is a loose bolt on the shock mounts, when BrianxB installed my set he took it out for a spin on rough roads and said you either have the pop or you don't, it's a loose bolt on the top of the shocks, I didn't because he torqued them down like a ****, so check that first, if there's still a problem, re-do the shocks one by one until the problem's fixed so you don't spend 2 hours on the full redo, like take apart and redo one, test drive, then do another
goodluck and if you didn't do it take it back and tell them what I told you, it's not normal to any degree
Old Feb 1, 2005 | 08:07 PM
bullitt44's Avatar
Default Re: problems with Tein Ss
Check the axels and steering rack!
jdlong
May 17, 2018 05:20 PM
danielv
Aug 26, 2015 07:14 PM
anthonyTC2
May 18, 2015 12:04 AM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
