pictures of air lift/easy street at full lift
Old Feb 2, 2005 | 12:01 PM
Default pictures of air lift/easy street at full lift
i'm looking for pictures of xb's at full lift with the easystreet/ airl lift front struts. thanx guys.
Old Feb 2, 2005 | 01:01 PM
Tamago's Avatar
they have a website?
Old Feb 2, 2005 | 02:27 PM
BrianxB's Avatar
they dont have it at full lift. Youll have to drive around with lower than full lift for a nice ride though. The car sits low even at full lift because the strut is shorter than stock.
Old Feb 2, 2005 | 03:46 PM
rolex87's Avatar
check out phil's car at the shop, or se it when my kit is on. It doesn't get super high, as the strut is lower.
Old Feb 2, 2005 | 06:08 PM
yeah i don't want super high i'm just wondering how high it is , sean(mybox) is making it seems like it's too low for daily use.
Old Feb 2, 2005 | 06:32 PM
BrianxB's Avatar
its not too low for daily use. The two times I drove my car with the front on it never scraped anything....
Old Feb 3, 2005 | 02:47 AM
any pictures?
Old Feb 3, 2005 | 02:53 AM
squirrel's Avatar
I'd like a system that was full height at where I'm at now, with a ride as comfortable as it is right now. And then when I sit the xB down, it'll be 1/4 inch off of the ground.
Old Feb 3, 2005 | 02:58 AM
BrianxB's Avatar
a 1/4" wont happen without cutting quite a few things. You could get pretty close though if you ran low pro tires on some 15" wheels.
Old Feb 3, 2005 | 03:01 AM
squirrel's Avatar
Even if I wanted the bottom edge of the lip kit slightly above ground? I have 17s w/ 40 series tires right now.
Old Feb 3, 2005 | 03:15 AM
BrianxB's Avatar
doubtful. Your wheels should be right around the same size as stockers. My car sat about 1.5~1.8" off the ground dumped. The wheelwell plastics sat right on top of the tire, literally.
Old Feb 3, 2005 | 03:32 AM
squirrel , add a deeper lip .
Old Feb 3, 2005 | 04:30 AM
abbfanuc's Avatar
easily solved...............let your air out of your tires!!!
Old Feb 3, 2005 | 04:45 AM
squirrel's Avatar
How about I just remove my wheel well liners?
(Hey Chris! When are you coming back to the Bay Area? Problem solved yet?)
Old Feb 3, 2005 | 05:01 AM
the wheel well liners dont lets ya go lower but they let you roll when yer at full drop.
Old Feb 3, 2005 | 05:03 AM
rolex87's Avatar
I know Sean will chime in, but he's using more than just the standard airlift kit. his camber plates are also smaller than stock (i believe). I think that's why he's so low, other than his super cool JDMness.
Old Feb 3, 2005 | 05:25 AM
squirrel's Avatar
Maybe I won't go air then, and just get HKS coilover to replace the TEIN Wagons.
Old Feb 3, 2005 | 05:40 AM
sean's kit is busted , bad seals i believe . he has some on the way . and a secret mod
Old Feb 3, 2005 | 06:03 AM
rolex87's Avatar
all his mods are secret. pretty soon his jet engine will make all you fools.......oops, i gave it away
Old Feb 3, 2005 | 06:09 AM
squirrel's Avatar
Man, that WAS my secret mod for saturday!
