will these rims fit my xb???
Old Feb 2, 2005 | 09:41 PM
dubfrk7's Avatar
Default will these rims fit my xb???
im looking to get zinik adrians rims. they are 18x7.5 with a +42 offset on 215/35/18 tires. will they fit without rubbing? if not what will i need to do to make them work? my xb is stock hight now but i will be lowering it in the spring.
Old Feb 2, 2005 | 09:42 PM
JdMBboFSD's Avatar
Default Re: will these rims fit my xb???
i am running the same setup ....but i have df-210's ...still no rubbing....
Old Feb 2, 2005 | 10:07 PM
dubfrk7's Avatar
so they dont rub at all? is your xb lowered?
Old Feb 2, 2005 | 10:41 PM
TheScionicMan's Avatar
Just make sure with a +42 offset that they don't contact the trailing arm in the rear. If it's tight, you may want to add some spacer shims from onetongarage.com. You may want them to flush it out with the outside edge too.
Old Feb 2, 2005 | 10:59 PM
dubfrk7's Avatar
that won't make my wheel bearings wear prematurely will it?
Old Feb 2, 2005 | 11:17 PM
no, the shims go behind the hub assembly pushing the whole thing out as opposed to spacers that extend from the front which is what I think you're thinking of...
mama22
Mar 20, 2015 04:59 PM
Sagara09
Feb 28, 2015 06:58 AM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
royder1976
Oct 8, 2003 03:12 PM
