Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge
Register Forgot Password?
Reply
Old 10-21-2009, 04:53 AM   #1
13edge
13edge's Avatar
13edge 38/M
Default Hesitation at idle...
Just lately, the last two days or so, I began noticing... something. It might be a miss, hesitation, exhaust hiccup, something like that. It happens sporadically, and only at idle, and it's starting to happen more frequently, maybe 6-8 times per minute. I've noticed no change in RPM's when it happens. My xB is a bone stock '06 with 19.5k miles, 5 speed, and of course JUST out of warranty.
Any ideas on a cause?
13edge is offline   Reply With Quote
Old 10-21-2009, 05:34 AM   #2
Murphys_Law
Murphys_Law's Avatar
Murphys_Law 28/M
my Tc occasionally does the same thing ive read its a dirty throttle body
Nothing feels better than falling in love with your car again
1,000 post on 9:48pm 12-20-2009
Murphys_Law is offline   Reply With Quote
Old 10-21-2009, 09:42 AM   #3
bearcave
Scion Apocalypse
bearcave's Avatar
bearcave 71/M
Try to rule out the usual suspects. Is your check engine lite on; are you throwing any codes? Have you checked your spark plugs (check for unusual wear, gap)? Is your air filter dirty? Do you notice any new leak stains where you park your car? Do you have a sound system; how's your battery voltage? If more than 3 yrs old, it may need to be replaced. Bat should show 12v cold and 13.5-14v running.
Google+
bearcave is offline   Reply With Quote
Old 10-23-2009, 04:09 PM   #4
13edge
13edge's Avatar
13edge 38/M
bearcave is like nostradamus. Came back on to post what I ended up doing-
checked my plugs (fine), changed the air filter, used dry gas on a full new tank of 93 octane. Hesitation is gone. It was one of those three things. Wish I had done them one at a time to be more precise.
Thanks for the replies.
One thing I do notice is that the maintenance required light does blink/flash a few times after I start the engine, but it goes away. From what I recall reading, this is just a Toyota safety thing, right?
Old 10-23-2009, 04:29 PM   #5
Jan06xB
Jan06xB's Avatar
Jan06xB 58/M
NOT your plugs then and not the air filter it was some dirty gas maybe just water . . . the blinking Maintenance Required happens every 5-6k miles and will start by blinking after starting and then will stay on at the set mileage. Usually reset by the Toyota/Scion service when the oil is changed or you can reset it with the trip odometer button.
Jan - 06xB
www.GasSavers.org
Jan06xB is offline   Reply With Quote
Old 10-23-2009, 05:28 PM   #6
burstaneurysm
Admin
Assistant Admin
burstaneurysm's Avatar
burstaneurysm 29/M
burstaneurysm burstaneurysm drbold burstaneurysm
Send a message via AIM to burstaneurysm
Yep, the blinking maintenance light is just indicating that you're close to the oil change increment.
-- Ian --
Please read and familiarize yourself with ScionLife rules.
Quote:
Originally Posted by cavalierkid888 View Post
zOmg! I just duck taped a sway bar to my fridge, and now it's drifting all over the kitchen!
burstaneurysm is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
8, blinks, camry, dry, flashes, gas, hesitation, hiccup, light, maint, maintenance, plugs, required, scion, spark, starting, tc, times, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
