2004-2006.5 [NCP61]
xA Blow off valve?
Old Feb 5, 2005 | 11:02 PM
DJRemiasz's Avatar
Default xA Blow off valve?
I was looking around google but I couldnt find out this question. I recently bought a xA stoc,k brand new 2005 and wanted to know if I could buy a blow off valve for it. (of course is manual/stick shift) Are there any requirements for it? Thanks.
Old Feb 5, 2005 | 11:12 PM
Bouncer's Avatar
Scion Dynasty
...uh...yeah...a supercharger or turbo charger....
a Blow-Off Valve has an accual purpose, it doesn't just sound cool.
A BOV is just a big capacity valve that opens when there’s a strong manifold vacuum present. Well, that’s how all standard ones work, anyway. In fact, what the valve is designed to do is vent the pressure build-up that otherwise occurs between the closing throttle and the still-spinning turbo.
But if you want the valve to make lots of noise, install a whistle in its outlet. Seriously. It works...
I hope that helps
Old Feb 6, 2005 | 01:00 AM
chipzxb's Avatar
You need a something to make that baby blow first....
Old Feb 6, 2005 | 01:25 AM
dgHotLava's Avatar
Default Re: xA Blow off valve?
Old Feb 6, 2005 | 03:42 AM
IS300Turbo's Avatar
Old Feb 6, 2005 | 03:54 AM
IS300Turbo's Avatar
I hope that helps
Before you lecture make sure you know what you are talking about. First, that diagram IS WRONG. A Blow-Off valve has nothing to do with manifold or plenum pressure. It's main function is to prevent compressor surge. There is something called a "Throttle Body" which when opened, allows air to run through it and into the motor, causing combustion. On a turbo car you are forcing compressed air through this hole. So what happends when you let off of the gas and the compressed air hits a wall. It goes back out the way it came...through the compressor causing compressor surge. A Blow-Off valve has a flapper basically using spring pressure to hold it close. When the throttle body closes, the air is forced out the blow-off valve...which makes a noise. Most cars need the air to go back into the intake (the pipe that goes into the turbo) because cars with MAF sensors had X amount of air going into the motor...but the blow off valve let Y amount of air out...causing Z quantity going into the motor. Because there was supposed to be more air in the motor, the car adds more fuel, causing the car to run rich...which degrades performance.
Old Feb 6, 2005 | 04:20 AM
duey's Avatar
I hope that helps
Before YOU lecture anybody you should get your facts straight.
First off here's a picture of a BOV
That top nipple goes to a vaccum source, typically AFTER the throttle body (also can be located in other areas i.e. fuel pressure riser ANYWHERE it can see vacuum or boost pressure). With out that vaccum line connected a BOV will NOT function, so it is a VERY important element of a BOV for it to work properly.
You are however correct on everything else.
I don't mean to come off like an ___ or anything its just you snapped at someone who gave out facts and you come off on him rather harsh.
-duey
Old Feb 6, 2005 | 06:20 AM
dante_b's Avatar
dont hate......educate!
fockers!
Old Feb 6, 2005 | 06:33 AM
^^^ Lol~ we learn something new each day
There are other options you can go if you want that BOV sound, HOWEVER they don't provide any actual function other than creating the whistle sound and make your car as ricey as a steam cooker
http://cgi.ebay.com/ebaymotors/ws/eB...category=33633
Old Feb 6, 2005 | 04:06 PM
Bouncer's Avatar
Scion Dynasty
I hope that helps
I don't know everything about turbo/superchargers and I won't pretend I do, but this is how the new BOV's work. I didn't mean to offend you...or anyone. Sorry if I did.
Old Feb 7, 2005 | 12:58 AM
DJRemiasz's Avatar
Default Thanks
Ya thanks for the answer I asked a mechnic and he said the same thing you need a turbocharger. But you said there are some ways to install a BOV so it doesnt do anything just sounds "cool" to be at least.
Old Feb 7, 2005 | 07:34 AM
XaRS0888's Avatar
Default Re: Thanks
you can weld it on the exhaust pipe so it'll sound louder than under the hood.
Old Feb 7, 2005 | 08:33 AM
XaRS0888's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=42610
WHY SPEND THE MONEY BUYING A BOV WHEN YOU GET THIS FOR MUCH MUCH LESS
Old Feb 7, 2005 | 12:04 PM
TakumiJr's Avatar
HKS SSQV BOV is so nice, but the bov sound get annoying after awhile though so atmpsheric bov are just to make pretty noises. You need a turbo before you can get a bov and yes you can always grab those fake electrical bov.
Old Feb 7, 2005 | 03:25 PM
chipzxb's Avatar
That is the sound of a turbo spool. Not a BOV.
Old Feb 7, 2005 | 10:50 PM
DJRemiasz's Avatar
Default ha
haha i havent heard of the fake turbocharger sound maker thing yet, but ill check it out look cool, and i heard that the sound of the bov can get annyoing at times...
Old Feb 7, 2005 | 10:57 PM
Bouncer's Avatar
Scion Dynasty
lol, hearing the same sound over and over again while you drive would get kinda annoying...but you gotta have love for the BOV.
I'd buy one, and everytime I heard that "Psssttt", I'd giggle like a lil school girl inside.
Old Feb 7, 2005 | 11:04 PM
SkyBox's Avatar
Whatever you do... don't buy one of those fake turbo sounding thingies....
Please don't! You will be made fun of!
I do like the BOV sound though... my favorite is driving by people at full boost and letting off the gas! Hahaha... I made a kid jump the other day, looked like he was going to ____ his pants! I have the TurboXS RFL and it's one loud ****...
I wouldn't turbo the Scion though, the rods look like toothpicks...
Old Feb 7, 2005 | 11:14 PM
DJRemiasz's Avatar
so why did you turbocharge yours?
Old Feb 8, 2005 | 03:27 AM
TakumiJr's Avatar
The car I'm buying in a week has a Greddy Type S bov, sounds pretty nice...But the HKS SSQV is by far the best sounding bov.
