RPM on stock head question.
Old Oct 26, 2009 | 06:19 PM
elcapetan's Avatar
Default RPM on stock head question.
Ok I will be getting E-manage Ultimate soon. I want to raise my redline a little bit because I run the 1/8th mile with the rev limiter hitting right before I finish. I wnat to raise it just a little bit so I can rev just slightly higher and run the 1/8th in 1st 2nd and 3rd. What is max rpm the stock head can handle. I have heard it is 7200 before valves float. I want to set my limiter a good 500 below where the valves will float. Anyone know for certain?
Old Oct 26, 2009 | 09:47 PM
my06tc's Avatar
i think 7200 also im sure someone can verify this
Old Oct 26, 2009 | 10:36 PM
elcapetan's Avatar
If it is in fact 7200 I will probably let my rev limiter to 7k.
Old Oct 26, 2009 | 11:14 PM
weezyfbayba's Avatar
id do 6500 to be safe
Old Oct 27, 2009 | 01:42 AM
ESEMRFOZZ13's Avatar
i take it thats a joke, since 07 rev that. im going 6800 and try to convert fuel to electric cut also.
Old Oct 27, 2009 | 03:13 AM
elcapetan's Avatar
yes I am 08 and that's where it is stock....
Old Oct 27, 2009 | 02:21 PM
6200 is around stock rev limit. do what u want
Old Oct 28, 2009 | 11:38 PM
6500 rpm for 2007 and up, since the law was put into place on how manufactures dyno, wich is why toyata bumped up compression added oil injectors, differant maf sensor and retuned ecu. it was either add more power on the tc or lower hp #'s advertised.
Old Oct 29, 2009 | 02:55 AM
elcapetan's Avatar
yes x2 07+ rev ot 6500 no problem.
Old Nov 2, 2009 | 03:51 PM
scuds03's Avatar
7000 is safe
Old Nov 5, 2009 | 04:28 AM
speedintc's Avatar
i went down to 8 once, went to second instead of 4th, but caught it so im sure 7200 would be fine but i would build it.
Old Nov 7, 2009 | 12:42 AM
scuds03's Avatar
RPM on stock head......
Old Nov 7, 2009 | 03:42 AM
rhythmnsmoke's Avatar
Music City Scions
I wouldn't go above 7k.
Old Nov 23, 2009 | 06:03 PM
johnhawkins's Avatar
What is safe RPM with Brian Crower Valave, Springs, Retainers and OEM cams??
Old Nov 23, 2009 | 06:36 PM
elcapetan's Avatar
I would think 8000 but u wont make power up there with the stock cams.
Old Nov 24, 2009 | 01:48 AM
BZinn1's Avatar
Was talking to a person locally who had the cams and such on the stock head with jsut a port and polish and he ran his at 6800,he got no more usable power at that RPM but it gave him more time on the shifts before it dropped between shifts to a usable point.
Old Nov 24, 2009 | 04:37 AM
TheQuietThings's Avatar
FWIW 6555 is what my aftermarket tachometer read as fuel cut
hampton1100
May 28, 2015 07:32 AM
SloTC1
Apr 2, 2015 07:11 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
k1114
Nov 30, 2014 01:40 AM
ToyTuners
Feb 22, 2004 10:34 PM
