Torque Dampers are they worth it?
Old 11-04-2009, 01:16 AM
jcXB's Avatar
Default Torque Dampers are they worth it?
Weapon R or Ingalls stiffy for xB1. Any one have it? Opinions? Reviews? I use my xB as a daily driver and I don't race or anything.
jcXB is offline
Old 11-04-2009, 03:08 AM
liltofuboix's Avatar
^ not really. unless you have turbo or your car has alot of torque. I really doubt it. and it also causes alot of interior noise you don't want. in addition its basically a car show piece if anything
liltofuboix is offline
Old 11-04-2009, 04:21 AM
drewskie14's Avatar
I did it to my tC and I noticed it just about got rid of skipping during starts when spinning the tires. Other than that it does create interior noise as a side effect... Really not worth the price imo
drewskie14 is offline
Old 11-04-2009, 08:50 AM
IV ACE
bB384's Avatar
I would rather invest the money in getting better motor mounts. But as you stated you don't race so it wouldn't be worth it since with either the mounts or damper you're going to get vibration and noise.
bB384 is offline
Old 11-04-2009, 01:03 PM
Black_Sheep_xB's Avatar
Your stock motor rocks pretty good at a hard launch, there is a noticeable change after installing the damper.. especially in a manual trans. I think it's a must if your into hard launches, and motor mounts wouldn't be a bad investment either.. but with just the damper, the motor barely moves.
Black_Sheep_xB is offline
Old 11-04-2009, 03:50 PM
jcXB's Avatar
Thanks for all of your input. I definitely don't do launches so this probably wouldn't be worth it. I'm going to invest the money in the progress rear sway bar instead. I read some really positive reviews about them. Thanks everyone!
jcXB is offline
Old 11-04-2009, 03:51 PM
burstaneurysm's Avatar
They do make a noticeable difference. PM'd too.
burstaneurysm is offline
Old 11-05-2009, 04:06 PM
Malibuguy's Avatar
i mixed about mine, i just installed an Ingalls 2 Tuesdays ago...it didn't get rid of my wheelhop issue...
Malibuguy is offline
Old 11-05-2009, 04:24 PM
maybe you have another issue causing it.. like a loose/broken mount somewhere. I had wheel hop before the ingalls, and not after personally.
Old 11-05-2009, 09:18 PM
Malibuguy's Avatar
the car has 42K on it...that may be possible...does anybody make stiffer mounts? I know i can get the trans mount done...its the same as my Tercel trans mount, but the rest of the mounts are different...
Old 11-05-2009, 09:28 PM
Jan06xB's Avatar
You get wheel hop when you dump the clutch too quick and break the wheels loose - then they get hot and grab then slip and get hot and grab back and forth making it hop and the engine mounts winding up a little makes it worse. Try slipping the clutch a little more smoothly . . . I get launches at about 3k rpm that really pull without any tire slippage going straight that surprise me sometimes and the car behind me as it disapears in the rear view mirror.
What I do have problems with is on damp days after a rain my clutch will chatter and buck like crazy with little or no gas as I let it out and I end up taking off in 2nd gear and slipping it a lot to dry out the clutch. At the same time the brakes make the front end nose dive with the slightest pressure until they dry out too.
Jan06xB is offline
Old 11-06-2009, 02:17 AM
Originally Posted by Malibuguy
does anybody make stiffer mounts?..
Energy has a kit.. all the mounts (inserts) for like 45-50 shipped
Old 11-06-2009, 02:28 AM
jct
jct's Avatar
no mad wheel hop with it installed nuff said
jct is offline
Old 11-06-2009, 11:46 AM
Malibuguy's Avatar
i tried looking on their site a few weeks ago...they only list stuff for the tC
Old 11-06-2009, 03:07 PM
http://www.dezod.com/pd-energy.cfm
and they have them on ebay too.
Old 11-06-2009, 04:57 PM
Malibuguy's Avatar
thanks...i'm going to buy those in a couple weeks
Old 11-21-2009, 05:10 AM
DelMarVa
SXT_HuntToKill's Avatar
wheel hope can also be caused by bad struts and sway bar linkage and bushings if worn... struts usually not to be checked and or replaced if needed every 60k-70k... im talking factory to not trd... linkage on my swaybars went bad at 30k replaced em with pollys from autozone $10 for universal kit fits perfect and $20 for the ubolt bushings also universal... work perfect...
SXT_HuntToKill is offline
Old 12-01-2009, 01:53 PM
Giupo's Avatar
I have tried the Energy Suspension mount insert in my car but the noise and vibrations are very unbearable! I have removed them immediately.
The Ingalls or Weapon R engine dumper produce the same effects?
Giupo is offline
Old 12-01-2009, 02:52 PM
jct
jct's Avatar
they do... but you can adjust the damper so they don't vibrate into the cab
jct is offline
Old 12-01-2009, 04:19 PM
Malibuguy's Avatar
my ingalls transfered noise (even with the suggested dynamat on it), but not any real noticeable extra vibration even at full tight...its for sale if anyone wants it, it maybe has 3 weeks of driving on it max
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
BlingSlade
10-19-2016 12:39 AM
Klunkerbill
11-09-2015 11:39 PM
Sgtfluffy16
09-30-2015 01:42 PM
JonathonK
09-22-2015 07:27 PM
Quick Reply: Torque Dampers are they worth it?
