header install
Old Jan 16, 2010 | 01:57 AM
mrhat's Avatar
Default header install
Hey guys, I went to the hobby shop on base to fix my squeeky spring and to install the headers. I fixed my spring really fast and felt good, went to knock out the header, and I cant get the two black brackets that attach to the header. I tried using a socket wrench and I wd40'd it and it wouldnt budge, I feel like I dont have enough room. Any advice on how to get it off, its the only thing stopping me!
Old Jan 16, 2010 | 04:46 AM
my06tc's Avatar
get a long breaker bar with the correct size socket i forget what size..but from the top of the car lookin down simply take the long breaker bar if can get one and use that as levarage to break it loose.....its easier then doing it from the bottom of the car ill never get done i had the same issue i just use a long breaker bar with a socket from the top of the car to gain more room
Old Jan 16, 2010 | 06:05 AM
rangerryda's Avatar
air ratchet ftw
Old Jan 16, 2010 | 01:57 PM
mrhat's Avatar
I fail, I had both a breaker bar and air ratchet with me. Ya I had the car on the lift, looked up from the bottom and said F that. There is those 2 metal pipes that are getting in my way.
Old Jan 16, 2010 | 02:13 PM
swdonogh's Avatar
How much power or torque do the headers really add and what is the inverstment? With them how much power would the power would the supercharger put out? How much were the headers and how many hours to install? Where should I purchase them? Stan
Old Jan 16, 2010 | 02:26 PM
mrhat's Avatar
I got ceramic DC headers shipped w/ antifouler for 140 used.
Old Jan 16, 2010 | 03:18 PM
my06tc's Avatar
those two black brackets on the header i used a long breaker bar cause i was heaving the same issue...but i was able to break them loose with the breaker bar i didnt have the car in the air either..i did spray some wd 40 let it sit for 20min
Old Jan 16, 2010 | 05:10 PM
rangerryda's Avatar
If I remember, I took them off with an air gun. I may or may not have used an extension but I don't remember them being that bad but who knows why they are giving you issues. Corrosion and heat can really make things a pain.
Old Jan 16, 2010 | 10:46 PM
my06tc's Avatar
just make sure the car is cold before working on it...
Old Jan 17, 2010 | 08:53 AM
Jackieee_tC's Avatar
For headers, you should go with either MMW or the Tsudo heres the link for the Tsudo: Price is $279 shipped and about $150 more for the MMW
http://cgi.ebay.com/ebaymotors/TSUDO...Q5fAccessories
I know those 2 in fact makes the most gains for 4-2-1 designs or headers.
For 4-1 designs go with the cheap ebay ones is the same as expensive Alphawerks ones, I got both and really you cant tell them apart beside the name on the Alphawerks header.
Changing the header is a good gain compared to an Intake or Axleback, but most of the time, raspy notes will sound from the exhaust.
Old Jan 17, 2010 | 06:27 PM
Blue_TC_Man's Avatar
get a box wrench, put it on the nut with the open end sticking out where you can turn it alittle, then get a long piece of pipe put it over the open end.
hold on to the end of the pipe and apply pressure till it comes loose,
or if you cant apply enough pressure, have a friend slowly raise the lift while you hold the pipe still, it will come then
tckid21
Mar 12, 2017 09:16 PM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
