Scion xB Lug Nuts
Old Feb 15, 2005 | 06:22 PM
wsb-unclebill's Avatar
Default Scion xB Lug Nuts
I need a little help with tuner lug nuts. Anyone know what size lug nuts to get or where to get them? The wheels I'm trying to mount are O.Z. F1 Cups.
I know they are the right hole pattern and offset, I'm just unsure what size/type of lug nuts to buy.
Thanks all.
Old Feb 15, 2005 | 06:33 PM
RPMxB's Avatar
Default Re: Scion xB Lug Nuts
Originally Posted by wsb-unclebill
I need a little help with tuner lug nuts. Anyone know what size lug nuts to get ... I'm just unsure what size/type of lug nuts to buy.
The following thread lists the size to be: M12x1.5
Scion Life Forums Forum Index -> Tread and Butter
FAQ: Wheel Fitment - ** Post Your Wheel/Tire Info Here**
https://www.scionlife.com/forums/viewtopic.php?t=348
Originally Posted by FAQ: Wheel Fitment thread
MISC INFORMATION
Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x5.5" +38 offset / 195/60-15
37 lbs per set
Alloy wheel: 16.7 lbs
RPM
Old Feb 16, 2005 | 02:45 AM
RacerxB's Avatar
Be sure the lug nut is designed to fit the wheel type. Most are acorn but if the seat in the wheel is different you might have to get a different lug nut. check with where you are buying the wheels
Old Feb 16, 2005 | 07:02 AM
rAndal's Avatar
Huh? I thought most aftermarket wheels were tapered, and not acorned? I do agree that you should double check though.
Also you only usually _need_ tuner style lugs if the holes in the wheel aren't large enough to fit a regular lugnut.
12thhawksfan
Jul 14, 2015 06:18 AM
scionlife
371
Jun 2, 2015 11:00 PM
HeyyJose
Mar 11, 2015 02:15 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
TheRedBox
12
Nov 21, 2003 01:32 AM
