45 offset wheels
Old Feb 16, 2005 | 09:53 PM
ugly_duck's Avatar
Default 45 offset wheels
Will a 45 offset 18x7.5 fit the xb? Im looking at 215 40 18 tires.
Old Feb 17, 2005 | 12:49 PM
violent_b's Avatar
yes, with spacers. I am running 18x7.5 with 215-35-18's. I had to use a spacer in the rear. I went with a 20mm spacer in the rear just because I wanted the tire to be flush. you can get away with the 10mm shims from One Ton Garage to clear. in the front I have not used any spacer but I haven't lowered my box yet. no rubbing lock to lock. we'll see with it lowered.
Old Feb 17, 2005 | 03:01 PM
ugly_duck's Avatar
Do the shims work for the front as well? If they do i would just use two sets of 10mm and im set. I ahve no desire to lower my car so its not an issue.
Old Feb 18, 2005 | 12:41 PM
violent_b's Avatar
the shims are for only the rear. since you are not lowering the car 10mm in the rear should be all you need. good luck and post some pics when you are done.
Sumolance
15
Jan 30, 2015 05:09 AM
gettoastedinthetoaster
Dec 29, 2014 11:39 PM
2010tc805
Scion tC 1G Wheel & Tire
Dec 12, 2014 06:47 PM
smilygo
Oct 5, 2003 09:51 AM
smilygo
Oct 1, 2003 07:03 AM
