Score one for the website folks
Old Feb 19, 2005 | 02:42 PM
Silver_toast's Avatar
Default Score one for the website folks
Went for hubcentric rings at Discount Tire ($15 - best price I have found), and they listed the stock "bore" at 56.10mm. I was positive that I read on this site that the ID is 54.1mm. The guy was really nice and gave me both sets for the price of one. I just need to return the set I don't use. Well, sure enough, it is 54.1mm. Thanks web folks!
Old Feb 19, 2005 | 09:21 PM
pharynx's Avatar
Whats the point of hubcentric rings? Are they like washers? Do you even need washers to space the wheel + the brake part?
Old Feb 19, 2005 | 09:29 PM
Besk_one's Avatar
No they are not like washers, most aftermarket rims cone with a center bore that is bigger than the center hubs on most cars.
if you don't use hubcentric rings, you run the risk of having your wheels slightly off-center, causing vibration, uneven tire wear, and possible breakage.
with the hubcentric rims pressed in the center of your wheels center bore, you guarentee that the wheel sits perfectly centered on the center hub
- Brian
Old Feb 20, 2005 | 04:07 AM
Excellent description of hubcentric rings - Thanks Brian
rain7905643
Jun 13, 2018 05:29 AM
Denzel
Oct 14, 2015 10:15 PM
Rayhofer
Sep 15, 2015 06:54 AM
SJMiller
Sep 12, 2015 06:33 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
