Taillight Question
Old Apr 14, 2010 | 05:08 PM
slaimd's Avatar
Default Taillight Question
I'm sure this has already been posted, but I can't find it...
Is there a taillight assembly I can buy that looks like this (see picture below), or is it only a DIY project? I have seen them referred to as OEM "red outs".
If they are an available item through a manufacturer, what's out there and where can I get them?
Thanks from a clueless toaster owner,
Alex
Old Apr 14, 2010 | 06:03 PM
spr0k3t's Avatar
That's custom... there are two ways to do it. Ether pull the lens completely apart, mask what you don't want painted, then use a special translucent paint on the inside of the lens. The second (less preferred) way is to vinyl over the outside where you want.
Then, there's a third way... pay someone else to do it for you. There are quite a few local peeps in AZ last I remember.
The alternative... go aftermarket.
Old Apr 16, 2010 | 03:40 PM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
It's custom. it's actually really easy to do!
https://www.scionlife.com/forums/scion-xb-1st-gen-aero-exterior-1607/%2Adiy%2A-tail-dissassembly-redout-yes-yet-another-way-27183/
https://www.scionlife.com/forums/scion-xb-1st-gen-aero-exterior-1607/howto-redout-tails-max2k-way-24212/
https://www.scionlife.com/forums/scion-xb-1st-gen-aero-exterior-1607/taillight-red-out-how-7542/
the first one is how i did it. BE CAREFUL, you can crack your tail light doing the screwdriver method without "baking" it, but it's not a big deal. just take it out (like 5 minutes, easy as pie), pop out the plastic, spray red in the areas you want red, and reverse.
*eidt*
here's a pic of boxzila's rear
Old Apr 16, 2010 | 03:49 PM
Big_Bird's Avatar
Yeah as stated before, they are DIY only. I have mine done too.
Kind of a bad pic, but you get it.
Old Apr 17, 2010 | 02:04 PM
Zman's Avatar
I have mine done like that and they are sitting in the attic.
I should post to ebay.
It's not difficult if you heat them up enough to make it easy to open them. Mine cooled down and I got a couple cracks on the edges when I opened them.
Old Apr 19, 2010 | 02:32 PM
monoxide101's Avatar
There's also a vinyl overlay with that look that can be found on ebay. I've never seen it in person though. I did the bake n paint on mine.
Old Apr 26, 2010 | 10:03 PM
elmaximov1's Avatar
Does anyone live in Los Angeles, Ca? I've been wanting to paint mine but i dont want to mess up anything.
Old Apr 27, 2010 | 06:06 AM
spr0k3t's Avatar
Dude, there are like tons of scion owners in SoCal. Check the regional posts and you'll see quite a bit of activity.
Old Apr 27, 2010 | 04:47 PM
burstaneurysm's Avatar
It's pretty easy. Just take your time masking off what you don't want painted and use even coats.
Old Apr 27, 2010 | 05:06 PM
SEXB909's Avatar
If you dont wanna do it, hit up Just!n or Kahuna and they can do it for ya. They live in the AZ region. Let them know that Kirby sent cha.
Old May 18, 2010 | 04:51 AM
elmaximov1's Avatar
So they live in Az, is there anyone near Los Angeles? I really want to smoke them but i'd rather have someone from this forum help me :D
Old May 18, 2010 | 12:55 PM
bbszero's Avatar
Pick up a used set of stockies and use them, then if you goof up, you still have your OG's. The best way to learn this stuff is to just jump in and do it, using the DIY's and advice from guys here.
Old May 27, 2010 | 12:40 AM
bBking56's Avatar
i have the same question..been looking for red tail lights wit clear in the bottom..im tryin to do a jdm look wit my bB..so far i only seen 1 website wit these kind of tail lights..but wats the easiest way nd cheapest way to do this??
Old May 27, 2010 | 01:38 AM
spr0k3t's Avatar
Check the threads posted above by mrfuzzy. Should give you the information you are looking for. Also, check the pictures over at
bbsquad for some general ideas.
Old May 27, 2010 | 02:20 AM
bBking56's Avatar
oh ok kool..but do i have to have the standard OEM tail lights that komes wit it stock?? kuz i have a different set of tail light..but im pretty sure its OEM stock tail lights..my is not the white klear looking tail lights..my has to circles on it..1 for the break lights nd the other is for the signal lights..then it has a white square light for da reverse light on the bottom..i kno its konfusing how i explained it but heres a link so u kan see wat it looks like
http://www.carid.com/2005-scion-xb-t...hts-71452.html
anyways kan i still paint da lens red and kome out wit the same result wit this tail lights
thnx bro
Old May 27, 2010 | 11:31 AM
spr0k3t's Avatar
Your post was hard to read. Just curious; is English not your native language or was that posted through t9 text on a phone?
I'm sure if you want to open those aftermarket taillights, you could still mask and paint without any problems. However, since the lens has no faceting, you might be better of doing a vinyl overlay instead.
Old May 27, 2010 | 02:33 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
my buddy opened mine to paint the inside
its just dirty, but the paint is flawless and since its on the inside, it looks all even
Old May 27, 2010 | 11:21 PM
bBking56's Avatar
haha im sorry. Yeah i was replying thru my phone. Anyways can i still open my tail lights and paint it and get the same result? Or do you think that it will look different?? Because i want to try it but i just want to make sure that i get tha same result. And if i do it what do i paint it with?? Can i use the red tint spray?? Or is it a different type of paint?
Old May 27, 2010 | 11:27 PM
spr0k3t's Avatar
Thank god man... I was starting to worry. hahaha!
For the type of paint used, there's the red tint spray that works. Then there's "testors red taillight" paint that's used on model cars, but it works fantastic. I've heard Krylon also makes a red tint that works well.
Old May 28, 2010 | 12:52 AM
bBking56's Avatar
haha im sorry for asking so many questions, because i havent done anything like this to my car and i dont want my first time doing this to turn into a horrible job, but this is what ive done to my tail lights. I bought a pre-cut smoked vinyl tint on ebay. i put it on myself. So i was planing to buy a red tint vinyl instead. Because im going for a JDM look for my box. So i went here to look for advices and this forum is very helpful. BUT it is kind of confusing how to do it. And i heard that if i put my lights in the oven and let it get hot. Theres alot of chances to crack the lenses and im scared to do it myself. SO what's your best advice for me? Should i get the vinyl tint instead or should i paint the lens? Because if i vinyl it, i dont think that i would get the result i want. And just wondering where can i get the paint?
