Recommended tire sizes for 17" rims...
Old Feb 3, 2004 | 08:13 PM
young-nyc's Avatar
Default Recommended tire sizes for 17" rims...
Hi all,
this is my first post on this forum..
i am thinking of purchasing some 17" rims however
i need all season tires living in NYC, and i think 18"s are out of the question.
I was wondering what is the best application for 17's?
can you get 205/45? i want the higher sidewall and think that 40 will be too low.
If not i think i might just have to stick to stock 15's
thank you.
Old Feb 3, 2004 | 08:18 PM
randode's Avatar
Wagonistas
https://www.scionlife.com/forums/viewtopic.php?t=348
WHEEL FITMENT INFORMATION
It is assumed that these figures will work on both the xA and the xB, but most are from xB owner's personal comments.
WHEEL SIZE . . OFFSET RANGE . . TIRE SIZES . . . COMMENTS
19x8.0 . . . . . . . 40 . . . . . . . . . . . . . 215/35-19 . . . . Rubs under hard cornering
18x7.0 . . . . . . . 28-32 . . . . . . . . . . 215/35-18
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . . Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . 215/35-18
18x8.0 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x8.5 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x9.0 . . . . . . . 31 . . . . . . . . . . . . . 225/40-18 . . . . Mentioned by 'rampagesd'
17x7.0 . . . . . . . 28-42 . . . . . . . . . . 205/40-17
17x7.5 . . . . . . . 30-40 . . . . . . . . . . 215/40-17
17x8.5 . . . . . . . 16 . . . . . . . . . . . . . 215/40-17 . . . . Front doesn't rub, mentioned by Oper8r
17x9.0 . . . . . . . 17 . . . . . . . . . . . . . 215/40-17 . . . . Rear needs rolled fenders, mentioned by Oper8r
16x7.0 . . . . . . . 33 . . . . . . . . . . . . . 205/55-16 . . . . Front rubs slightly in front, mentioned by oj411
16x7.0 . . . . . . . 25-35 . . . . . . . . . . 205/40-16
16x7.5 . . . . . . . 38-40 . . . . . . . . . . 215/40-16
15x7.0? . . . . . . 38 . . . . . . . . . . . . . 185/60-15 . . . . Stock Size
MISC INFORMATION
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x5.5" +38 offset / 195/60-15
37 lbs per set
Alloy wheel: 16.7 lbs
Other Vehicles With Interchangable Wheels
Toyota Celica (1988-1989)
Toyota Corolla (1988-2001)
Toyota Corolla Wagon (1988-1996)
Toyota Echo
Toyota MR2 (1986-1990)
Toyota Paseo
Toyota Tercel (1989-199
Toyota MR2 Spyder (2000-)
Old Feb 3, 2004 | 08:22 PM
young-nyc's Avatar
wholly cow that's a whole lot of information thanks..
but i don't see anyone with the 205/45 set up for 17's
or for that matter 205/45 for 16's..i know that 205/45 will fit for the 16's since that's the tire package offered by TRD 16"
Old Feb 3, 2004 | 08:23 PM
scionspecialistvegas's Avatar
Darren, Randy post should get a sticky or put in archieves that is valuable info.
Old Feb 3, 2004 | 08:49 PM
randode's Avatar
Wagonistas
im running 215/40/17 on a 7.5" x 17" wheel with 40mm offset and i love it.
as far a posting this as a sticky, it allready is
Old Feb 3, 2004 | 09:01 PM
scionaraxb's Avatar
Im running 215/40/17 on a 7.5" x 17" wheel with 40mm offset.......too
Old Feb 3, 2004 | 09:07 PM
bobbyboshay's Avatar
I'm running 215/45/17 with a 40 offset and I have NOT lowered yet
Old Feb 3, 2004 | 09:10 PM
scionaraxb's Avatar
That'll be the next size I buy.
Old Feb 3, 2004 | 09:56 PM
wonderworm's Avatar
215/45/17 42 offset, stock springs = no rubbing. Looks great.
I'd get the lowest offset you can find to push the tire more flush with the wheel well.
Old Feb 3, 2004 | 10:11 PM
yanges's Avatar
me too
Old Feb 4, 2004 | 01:24 AM
young-nyc's Avatar
NICE..
i think i am going for the 215/45 17 set up as well...
i went to the dealer lot today, and they had a demo with that size...
so for you guys with this size...you have no rubbing issues right?
i don't plan on lowering the car.
Old Feb 4, 2004 | 02:32 AM
hnefrdo's Avatar
im going with 205 40 17's
Old Feb 4, 2004 | 03:04 AM
NICE..
Just remember that you are going just a little faster than you're speedometer says and you are showing less miles than you actually traveled. Nothing to stress over.
Old Feb 4, 2004 | 03:08 AM
westsype's Avatar
I'm thinkin about 205/45/17 on 8 inch width rims. What do u think?
Old Feb 4, 2004 | 06:47 AM
young-nyc's Avatar
hey showing less miles is good..
besides it's very neglible i believe.
Old Feb 4, 2004 | 07:19 AM
Sgt_Scion's Avatar
im running 215-40-17 with a 35 off set. And I have no rubbing at all. And not too much difference in the ride either. One thing I do notice is that they grab the road alot more and deffinatly sticks better in the rain.
Old Feb 5, 2004 | 01:42 AM
yanges's Avatar
i think that 215/45/17 would be better on an 7.5-8 inch rim....
just my personal preference...
now if you are going to lower it, the 205 might be better...
Old Feb 6, 2004 | 04:47 AM
westsype's Avatar
yep dropping it duece inches
Old Feb 6, 2004 | 10:28 PM
HemanC's Avatar
I have 17x7, 36offset. I want to get 215/45/17 but not sure if it will fit or not. If they fit, can I still have a 2" drop? Help guys.....
Old Feb 7, 2004 | 12:36 AM
CBSIMONSEZ's Avatar
According to the tire calculator, you will be moving faster then you think running a 215/45R17 tire. Your spedo will read 60, and your doing 62+. Closest thing to stock is 215/40R17, almost dead on.
http://www.saturnperformance.com/tech/tiresize/
for those using the 215/45's, how much of a sidewall is there?
