Passenger window doesn't work.
Old May 9, 2010 | 04:48 AM
Sweeeeet's Avatar
Default Passenger window doesn't work.
When i purchased the car the passenger window didn't work for the passengers switch it only work from the drivers. Shortly after it stopped working from the drivers side switch. Im getting solid lights on each switch so i assumed its not a reset but I reset it anyway. I opened the panel and used an ohm meter on the switch but it wasn't getting any power. Where do I go from here ?
Old May 9, 2010 | 04:51 AM
A-snell's Avatar
the dealership should fix it for you. I would try and get them to take care of it. they should of never sold it without fixing that first.
Old May 9, 2010 | 05:31 AM
willy213's Avatar
Try adding more passenger window fluid.
Old May 9, 2010 | 05:34 AM
A-snell's Avatar
now that's jsut messed up right there..
Old May 9, 2010 | 05:37 AM
willy213's Avatar
That is pretty messed up.
But here u go OP. Search next time. This has occurred to everyone
http://lmgtfy.com/?q=SCION+TC+WINDOW+RESET
Old May 9, 2010 | 06:06 AM
Sweeeeet's Avatar
Ive done my research. Ive also stated that i did the reset.
Old May 9, 2010 | 07:08 AM
SquallLHeart's Avatar
you fail.
sounds like the car does have actual issues. you might want to get it checked out. my assumption is that either the motor is out or there's a wiring problem somewhere.
Old May 9, 2010 | 08:06 AM
willy213's Avatar
That's what I get for not reading the entire post.
I fail...
Old May 9, 2010 | 03:37 PM
Sweeeeet's Avatar
The (kick panel) fuse box under the dash is missing the cover so i cant tell what the fuses are for. Can someone please post a picture of the cover with the fuse details. Thank you in advance.
Old May 14, 2010 | 11:13 PM
the owner's manual also lists the fuses and what they are for.
Old May 19, 2010 | 04:19 PM
oxxomxxo's Avatar
check fuses
Old May 19, 2010 | 09:02 PM
Sweeeeet's Avatar
I don't have the Manuel either >.<
Old May 19, 2010 | 10:25 PM
i hope you don't have a Manuel unless you're into that type of stuff.
it's manual. silly.
anyway, this should help:
http://scionlife.org/Scion_Docs/2006_Scion_tC_om/8.pdf
Old May 20, 2010 | 02:32 PM
Sweeeeet's Avatar
LOL!!! DOOOh didn't see that one coming.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
CPL_Radar
Mar 5, 2015 05:42 AM
pier0723
Dec 3, 2014 03:38 PM
