need help with coilovers
Old Feb 22, 2005 | 01:40 AM
obone's Avatar
StyleWagons
Default need help with coilovers
I just bought some cheap coilovers from ebay and the front ones will not fit over the strut has anyone else had the same problem or have heard of this problem. Thanks in advance
Old Feb 22, 2005 | 02:01 AM
Yes , what you have to do is remove the little brass piece halfway down the strut , do so with a screwdriver and hammer , do not worry it is not dangerous on these vehicles , after that you slip the sleeves on then tighten them to the shock body , after that you replace the brass cap with a few light taps of the hammer. ala zam!!! oh and so you know unlike what the ebay listing says the lowest you can possible go is just over 3 inches up front and about 2.5 or so in the back. good luck and post pics when finished!!!
Old Feb 22, 2005 | 12:34 PM
Munch's Avatar
YUP!! That's how it's done.
Old Feb 22, 2005 | 07:42 PM
unlmtdndeavor's Avatar
can someone post some pics up of them slammed. also, how low can you go with 22/34/19's?
Old Feb 22, 2005 | 08:00 PM
Sassyxa's Avatar
I was just wondering what is the ride quality like w/the cheap setup I wanted ground control but they said thye had protype's and they didnt work so if you could post pics then i could decids on coilovers or just springs
Thank you Sassy
Old Feb 22, 2005 | 08:02 PM
Sassyxa's Avatar
Thank you Sassy
Old Feb 22, 2005 | 08:04 PM
I'll post some pics , the lower you go the crappier the ride but i'm used to slammed cars so it's not that bad , worse part is the spring rate is high.
Since this pic I lowered it about .5 all the way around
Old Feb 23, 2005 | 12:26 AM
TexasIceBox's Avatar
StyleWagons
nice
Old Feb 23, 2005 | 12:47 AM
Originally Posted by TexasIceBox
nice
Thank you !! As of right now the front is at about 2.75 inch drop and the rear is about 2.5 inch , this is as low as the rears can possibly go , the fronts could go about half an inch lower but there would be absolutely no shock travel left , I like a little bit of shock travel. This is my intermediate suspension between stock and air ride. I have been very happy with them , I am lower than just about all other springs out there , the ride is stiff but not unbearable. My springs cost about 100 shipped , I believe they were either a-spec brand or rs-type brand . I purchased them from either k2motor , vertexracing , or racing9motor on ebay , lol . I forget and it's too old of a listing to check , I frequent all of those sellers , all are very good guys , with good service , quick shipping and just about the best products out there for the money.
Old Feb 23, 2005 | 04:00 AM
obone's Avatar
StyleWagons
Default just put them on
Well I got them on Thanks to texasicebox and dmoldman.. thanks guys.. rear still alittle high hope it settles some.. front looks sweet will try and get some pics on
Old Feb 23, 2005 | 09:27 AM
Default Re: just put them on
To get the rear as low as possible remove the adjustable part from the rear and use the actual rear perch . It gave me an extra .5-.75 inch. but you could always cut the springs a bit.
Old Feb 26, 2005 | 11:37 PM
jynx's Avatar
looks great!!!
Old Feb 28, 2005 | 02:29 AM
obone's Avatar
StyleWagons
Default here are the pics from mine...
http://www.imagedump.com/index.cgi?pick=get&tp=212054
http://www.imagedump.com/index.cgi?pick=get&tp=212068
http://www.imagedump.com/index.cgi?pick=get&tp=212069
greytc
Oct 26, 2015 07:53 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
