hich bolt on 11487
I have one just like this guys. A nice stuff holder. He did a much nicer job showing off the work.The cooler idea is right on
http://www.gadgetjq.com/trailer.htm
I have been pullin it behind my 65 vw sundial stuffed with enough camping gear ext. for 5 people. Two are teenage girls! No wind drag, or loss of room inside.
I only have about 50 hp in that, so the box should do just fine.
Rob
Rob
I just placed an order yesterday. Talked to Hector @ USA Hitch:
http://www.usa-trailer-hitches.com
They are three different companies in one.
The toll free is 866-308-9051, 9052, 9057.
Curt has 20 in stock.
Rob
Rob
I just ordered one from:
http://www.hitchsource.com/product_i...ducts_id=27266
They have a picture and the installation instructions on their site. It looks like a pretty straight forward install. I can't wait...
If you look @ my earlier post I have pics, a scorce for $125.00, the install specs, phone #'s. I did all the search work and passed it on.
I thought that is why we hang out on the scionlife list?
Its all about "spreadin the love" of knowledge
I have one. My camera is not working so no pics.
This is what I have to say. Very much worth it. The installation is very simple. The only hard part is removing two exhaust hangers to move the exhaust a bit. You have to do it in order to place the hitch into position. One installed the exhaust goes back on and no interference. You do not have to cut the bumper cover. the receiver is about 1/2 inch below the bumper cover. I think it is strong enough to tow a small trailer like a personal watercraft or those small trailers you see at harbor freight.
I paid $120 including shipping from a guy on ebay.
Where did you guys (hitch owners) drop your wires from to go to the trailer? Did you just extend them, and hang them out the rear hatch when needed, or did you drill, and drop them out the bottom?
MattB
MattB
You can do everything through the air exhust vents. The two removable grills in the back.
Just pick a side, and run a wire for the opposit side turn signal through the underside.
When you remove the vent grills pull out the chunk of gray insulation. You should see your foot! I am using the Hoppi protection/conversion box. You need to get a hot wire from up front for it. I just ran it under the box. Went a little heavier and it powers my rear sub also.
I have not found a plug and play kit yet if someone else knows of a part # .
Rob
Rob
They may have one for the box, I haven't checked. I picked mine up at Auto zone for
about $30.00. Its for a Mazda. I just cut the plugs off and wire it direct. It is the same for all cars with seprate brake and turn signals.. It would be nice to find a direct set up.
http://www.truckcustomizers.com/prod...4HOP428.7.html
Rob
Rob
I just got mine installed and its great. Installation only took a half hour and it was a true bolt on with everything included. I got mine at:
Originally Posted by Driver Lost
Curt mfg. makes a no cutting or drilling hitch for the xB.
Its not yet on dealer web sites, too new I guess.
http://www.curtmfg.com
It's about $125.00 +s&h
I'm working on some pics, for now I have them on my profile page
https://www.scionlife.com/?Driver%20Lost
The install spec sheet:
http://www.hitchesonline.com/pdf/11487-INS.pdf
Has anyone installed this? Wisconsin tcm member xB shown?
Rob
Rob
