Hotchkis front sway bar question.
Old Feb 23, 2005 | 03:33 AM
aslugger3b's Avatar
Default Hotchkis front sway bar question.
does any one know were i can get the hotchikis front sway bar. i dont want the set because i have the TRD rear sway bar i would like the front one only.
Old Feb 23, 2005 | 10:40 PM
jrv2000's Avatar
there is a reason that they come as a set, the front was made to work with the rear, and vice versa. As far as i know no one sells them individually, but iven if you found someone that did i wouldn't reccommend just putting the front one on without the rear.
Old Feb 24, 2005 | 07:20 AM
hahaitzskippy's Avatar
BAD idea
i highly suggest u get a stiffer rear if you get a stiffer front sway
in other words
if you get the hotchkis front sway, your car will be to stiff and the rear cant hold it sellf well enough so you might experience turbulence? haha that to balance that out, hotchkis made an even stiffer rear.
get the set. if you lik it, sell the TRD, if not sell the hotchkis
Old Feb 24, 2005 | 07:30 AM
jrv2000's Avatar
just stick with the hotchkis system, way better than TRD
Old Feb 24, 2005 | 09:04 AM
unlmtdndeavor's Avatar
for a fwd configuration...usually u should go with a rear only over a front only. so if you are planning on just doing one, do the rear. but just do yourself a favor and get the whole set
Old Feb 25, 2005 | 03:55 AM
motozen's Avatar
get the hotchkis... They are the shiznits. night and day... night ... and... day.
Old Feb 25, 2005 | 03:15 PM
240SXtoTC's Avatar
Are you referring to the hotchkis front strut tie bar that is a dealer option? or are the sway bars different?
Old Feb 25, 2005 | 09:23 PM
Sparks_Scion_TRD_Parts's Avatar
Default Re: Hotchkis front sway bar question.
I've got the sets for sale, but not just the front. I wouldn't recommend splitting then. You should be able to sell the TRD Rear pretty easily.
Ken
www.trdsparks.com
carid
Feb 12, 2015 11:54 AM
mark13018
Feb 6, 2015 08:57 AM
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Jan 9, 2015 02:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
