solve this RIM/TIRE/OFFSET equation... rim masters :)
Old Feb 25, 2005 | 02:03 PM
Soon2BxB's Avatar
Default solve this RIM/TIRE/OFFSET equation... rim masters :)
heres the variables = you give me the missing answer
18" rim .... 7.5 width
OTG rear shim spacers
215 40 18 tires
goldline springs
thing i need answered ...
what OFFSET for my rims so that i dont have any rubbing issues when i have the OTG rear shim and springs installed.. i want the rear flush with the fender
thanx a ton guys
Old Feb 25, 2005 | 03:31 PM
Bull's Avatar
+25-30 should be a good offset that'll get you flush (or close to it) front and rear without rubbing issues.
Old Feb 25, 2005 | 03:58 PM
Soon2BxB's Avatar
your saying get that offset in combination with the OTG spacers.. wouldnt that make the rear offset a a 15-20 offset... i can def see that causing issues
i need to know what offset to use taking into account ill be using the OTG rear shim spacers
thanx for the reply though ...
Old Feb 25, 2005 | 04:31 PM
squirrel's Avatar
Tom, if the wheels are 7.5 inches wide, you can definitely run a +42 offset and not worry about rubbing. The only problem I had before the OTG spacers were I needed a 3mm spacer for the back wheels. I know, that's what offset my wheels are, and when I added the OTG spacers everything was fine. NIce and flush. OH, and I'm on at least a 2.5 inch drop.
Old Feb 25, 2005 | 08:00 PM
Soon2BxB's Avatar
thanx man
and the 215 40 tires should work perfect with this combo right ?
thanx
Old Feb 25, 2005 | 08:19 PM
squirrel's Avatar
Originally Posted by Soon2BxB
thanx man
thanx
Yes, the 215/40-18s are slightly taller, but its a toss up between that size and 215/35-18s.
Old Feb 25, 2005 | 08:39 PM
Soon2BxB's Avatar
thanx man
thanx
i def want a 215 40 .. i wont use a 35 because of the roads around here
heres something else to toss into the mix
a wheel i was looking at .. only comes in 18x7.5 with a +45 offset... i assume with the OTG rear shim spacers the back will be fine
but what about the front ? would i need a 3 mm spacer in the front to prevent rubbing or would a 45 offset in the front dropped on goldlines work ?
thanx again
Old Feb 25, 2005 | 09:26 PM
Munch's Avatar
thanx man
thanx
thanx again
You'll be fine with the 45mm offset in the front. I'm running 19x7.5 inch wheels 45mm offset with 225-35-19 inch tires, and I have no issues at all.
Old Feb 25, 2005 | 10:42 PM
squirrel's Avatar
Old Feb 26, 2005 | 12:16 AM
LavaBox_v1's Avatar
I have 7.5" wide +32 offset and 15mm H&R wheels spacers and if you look down from over the fender the wheel sits perfectly flush. The front is also 7.5" wide with a +32 offset but im using olny 5mm H&R wheel spacers and they are pretty damn flush.
The only thing with the 15mm rear wheel spacer is you have to use the Extended Wheel Studs H&R give you. But the look is AMAZING! Ill have pics up of the setup tomorrow!
Old Feb 27, 2005 | 07:50 AM
tinybigrig's Avatar
hey munch lets see pics of the new wheels
brent
Old Feb 28, 2005 | 02:57 AM
Bull's Avatar
Why don't you just get the proper offset wheels and skip the shims? 18x7.5 (+20) front and 18x9 (+25) rear, for example. Otherwise, run the shims and go with 18x7.5 +35 all around. I've seen guys who run 18x8 and +25 with no issues, so 18x7.5 +35 with a 10mm shim should be fine.
Old Feb 28, 2005 | 02:06 PM
Munch's Avatar
brent
SHHHHHHHH
Old Feb 28, 2005 | 10:03 PM
scion619's Avatar
Hey guys got my18" with 215/40 tires last week and I don't have rubbing issues. My question is if I were to drop it with goldlines will I then have any rubbing issues with these springs? If so then im thinking i'll have to with the trd's...
thanks
scion619
Old Mar 1, 2005 | 05:17 AM
hahajoey's Avatar
im running 8" wide in rear. im running a 25 offset
with about 5-7mm's of additional spacing. i can probably
swing another 2mm if i wanted to. but im pretty low to the floor,
and with 4 headsin my car.. my car is tucked.
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
