Rear struts to hold more weight
Old Jul 22, 2010 | 02:47 PM
XbbbbBox's Avatar
Default Rear struts to hold more weight
I have a 2005 xb - 127,000 miles - stock spring setup w/rear swaybar.
I replaced my stock rear struts with Monroe 5601.
I have a trailer hitch(don't flame me) that I use with my bike rack a couple of times a year.
I had a problem with cupping on my rear tires - the tire dealer said my rear struts were gone, and gave me a new set tires under warranty. I replaced the Monroes at this time with new struts and now after 5-6000 miles I am starting to get cupping on the rear tires again. Tire dealer says rear struts that cause this wear.
So I am going to replace the struts again (first time one strut may have been bad).
Should I just replace with the Monroe strut again? Should I use somthing like the Konis that are adjustable? Will they help with the weight - or is that purely the springs? One thing I noticed when going from stock struts to Monroe struts - when I put any weight in the way back, or 2 people in the back seat with weight in the way back the car does seam to sit lower than stock.
When the car is at rest it sits at stock height.
Any feedback is appreciated. Thank you.
Old Jul 22, 2010 | 05:20 PM
spr0k3t's Avatar
You need some spring helpers. It should get you started on what to look for.
http://www.suspensionconnection.com/...r-springs.html
You can increase or decrease the ride height with a simple tire pump.
Old Jul 22, 2010 | 10:58 PM
VIP_CAMO's Avatar
Big Sky Scion
I was thinking about those as well i need something to help me out when i load my car or have people in it because my tires rub but dont want to have to get air bags and lose my ride that my lowering springs offer me.Just something that will help with loads when i need it seems like a pretty cheap fix.Anyone have these?
Old Jul 23, 2010 | 04:03 AM
bbszero's Avatar
Check this out:
http://www.clubxb.com/forums/f15/diy...ags-34771.html
Old Jul 23, 2010 | 10:45 AM
spr0k3t's Avatar
I know someone local who has these. They work pretty good from what I've seen.
Old Jul 23, 2010 | 03:39 PM
XbbbbBox's Avatar
Default Spring bases
Thanks for the tips - it looks like air bags it is.
On the tutorial I see some adjustable spring bases - I am stock so I assume I do not need those? Is this correct?
Old Jul 23, 2010 | 04:50 PM
TheTransporter's Avatar
Get a stiffer spring. Road Magnets are designed to carry heavy loads and if you need something stiffer they custom build them for your application.
Old Jul 26, 2010 | 04:44 PM
XbbbbBox's Avatar
Thanks Transporter - I ordered set of custom springs from RoadMagnet...said may take a couple of trys to get the height right. He made up a pair for a locksmith that was carrying a lot of weight in the back of his XB. Cost was $165 shipped.
airmankevin1
Feb 14, 2018 01:23 PM
xa007xa
Feb 26, 2015 02:12 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
