Short throw shifter installation???
Old Aug 3, 2010 | 07:40 PM
Str33tKing's Avatar
Default Short throw shifter installation???
I was looking into getting a short throw shifter and I have heard mixed things on ease of installation. Anyone know if it is an easy install and time to install?
Old Aug 3, 2010 | 07:52 PM
RoboCop's Avatar
It's not exactly a hard installation. It's just some parts take more effort and it can get frustrating. My knuckles were beat up afterwords but it was definitely worth it.
Old Aug 3, 2010 | 08:06 PM
SquallLHeart's Avatar
easy install if you have the tools needed
if you don't have tools... well.. obviously it's gonna be a bit difficult, won't it?
with the right tools, you can do it in like 30 minutes.
Old Aug 3, 2010 | 09:52 PM
shadowler's Avatar
have u been going out to the meet lately SH?
Old Aug 4, 2010 | 12:04 AM
CliftonstC's Avatar
not a hard install. The 30 minutes it takes are more than worth it for the crisper shifts .
Old Aug 4, 2010 | 12:14 AM
Domo's Avatar
It is easy. Well, there is only one thing you would have to worry about...its that evil washer. I cringe at the idea of how long it took me to remove it.
Old Aug 4, 2010 | 12:16 AM
asianorange's Avatar
Depends on the kit. ie. the TRD kit comes with a complete cage assembly. Just swap it with the old and reconnect the shifter cables. Other kits are cheaper but you have to tap the stick out of the cage assembly like so: from what I've seen only the TRD comes with a complete cage assembly, everything else is a bit more involved.
tl;dr:
at best: console removal, 4 bolts and 3 cables.
at "worst:" some quality time with hand tools.
IMO, TRD is so modest you can't tell the difference.
Old Aug 4, 2010 | 01:33 AM
Spicy_McHaggiz's Avatar
Dr. Isotope used to sell a kit with the cage, easy swap.
Old Aug 4, 2010 | 06:44 PM
used to? he still can if he has people send him stuff..
and for me at least.. it's easy, if not easier, for me to swap out just the shifter part than replacing the whole assembly. ymmv.
Old Aug 5, 2010 | 12:45 AM
kevin091988's Avatar
simple. I did cage riser bushings, new shifter rod, and cable bushings in about 30 minutes. nothing about it is hard. You just have to have patience.
Old Aug 5, 2010 | 03:44 PM
Sparks_Scion_TRD_Parts's Avatar
Default Quick Shifter
If you are installing a TRD assembly it's a lot easier than taking everything a part. Here's a link to the tC TRD Shifter and the installs are in the upper right hand corner of the page so you can check it out. http://www.trdsparks.com/displaypart...0&parts_id=641
Ken
Old Aug 6, 2010 | 04:34 AM
PRODIGY3000's Avatar
Find a way to get plenty of light in there. I did mine outside in the afternoon sun w/ the roof open. Use a DIY from this site or instructions that come w/ the kit you buy and you'll be fine.
If you don't get a kit that comes with a new cage then you'll run into a step in the process that's simple as pie but is a b*tch to complete because you have little to no leverage in there. An hour and some curse words later its all over.
Old Aug 14, 2010 | 01:55 AM
mystik's Avatar
CinSity Scions
disconnecting the linkages from those spring loaded twist lock thingys was what gave me the most trouble...
Old Aug 22, 2010 | 12:03 AM
grumpy6489's Avatar
Just took care of mine the yesterday. this is the final result, and shifting is so much different now. Just gotta get used to it.
Old Aug 22, 2010 | 12:16 AM
egobuster1's Avatar
^^^ holy smokes thats short. what kit is that and how much of a drop
i got one from DR isotope and it took me probably 2 hrs to install it but the hardest and longest part was getting the white plastic ring off that actually hold the lever down in..everything else is pie
Old Aug 23, 2010 | 06:45 AM
lvlonkey's Avatar
got the doc i ss with the full cage. hardest part was the shifter cable lock but the whole process took around 30 mins.
Old Aug 24, 2010 | 07:48 PM
grumpy6489's Avatar
Its the TRD Short Shifter with a couple minor mods. I got a no name shifter cut it 3 inches. Driving is so much different, gotta get used to it now ahha
NonStopTuning
Jun 29, 2015 07:42 PM
SuBSiN
Mar 13, 2015 04:02 AM
disaster06
Dec 4, 2014 07:05 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
kidkamel
Oct 10, 2003 06:41 PM
