Exhaust grounding?
Old Mar 1, 2005 | 12:29 AM
Chimmy3's Avatar
Default Exhaust grounding?
anyone know
what is the deal with exhaust grounding?
does it do anything? Why does it do anything? and why do kits use the weird flat braided wire?
http://www.eautoworks.com/html/ORD-1-1-1-27590.cfm
Old Mar 1, 2005 | 12:42 AM
xmetalx's Avatar
Sun Automobile now offers specialized earthing straps to properly ground your xB exhaust system to the chassis. Based on research and development of the Hyper Ground System, the new exhaust earth is designed to maximize exhaust efficiency. Hot Earth exhaust and muffler ground wire can be install to your xB stock exhaust system, or aftermarket performance cat back and universal muffler system.
Hot Earth Exhaust Ground System for Scion xB Features:
-- Increase torque response
-- Reduced static electricity in exhaust
-- Reduced vibration noise from exhaust
-- Easy installation with common hand tools.
Old Mar 1, 2005 | 12:48 AM
snuppy's Avatar
hmmm... never seen that before...
i'm assuming since it's grounding muffler/exhaust to chassis, the braided wire handles vibrations/movement better than regular wire (?)...
dayam... 36 bucks...
Old Mar 1, 2005 | 12:49 AM
scooter123's Avatar
Default degauss
Two hints:
1: For the same reason that the hood has a ground strap
2: You'll get a better answer by posting in the ICE section
Old Mar 1, 2005 | 02:40 AM
Actually
the hood doesnt have a ground strap , at least not mine
ice? no it's power hungry
I will however call bs to all of these claims. any effect (at all) will be very minimal. . if it was 16 bucks I'd buy it.
Old Mar 1, 2005 | 02:45 AM
Minsk99's Avatar
Interesting. I'm in the process of installing an armature radio in my ride and some of the reading I've been doing has suggested grounding the exhaust system to reduce "noise" over the radio. I'm assuming that since the exhaust is a "conductive" extension all the way from the engine (header) that its basically the same thing as grounding any other engine part that is usually included in a grounding kit. Just a guess.
Old Mar 1, 2005 | 03:04 AM
Scott17's Avatar
StyleWagons
Pure junk! The reason they sell this stuff is naieve people buy it!
Old Mar 1, 2005 | 03:31 AM
scooter123's Avatar
Default ground wire, ground coffee, ground round
Sorry if I mislead. Every car I’ve ever owned has had a grounding strap for the hood. (And I’m not going outside now in a blizzard to scope the XB.) A car represents an electromagnetic field which affects radio reception. Any large metallic part which is in proximity to this field which either changes its alignment or has intermittent contact will alter radio wave access to the receiver. Everyone’s noticed how people walking around a radio or TV will affect reception. The hood and exhaust are imperfectly grounded through a hinge or hanger and will, through minor shifts and vibrations, create radio noise. I once got rid of a friend’s radio noise in a ’67 Mustang by ground strapping his doors. I’ve heard of improved radio reception by grounding trunk lids and hatches.
Grounding the exhaust shouldn’t affect horsepower unless the O2 sensor wants a better ground.
The next warm sunny day I’ll look at the XB’s hood and see where the ground is. That should be in June!
Old Mar 1, 2005 | 03:39 AM
Derk-xB's Avatar
Werd. That's gotta be the lamest scam I've ever heard of. Grounding out your exhaust system? Because your exhaust is carrying current? Damn, I hope not!
Old Mar 1, 2005 | 03:52 AM
Lonely_Raven's Avatar
I think the exhaust it pretty well grounded to the motor.
But that's just me.
Added torque my ___...
Old Mar 1, 2005 | 08:39 AM
B2FiNiTY's Avatar
Ha! What a scam.
Old Mar 1, 2005 | 04:46 PM
Kong's Avatar
Interesting find, I think it may not effect engine performance. Even if it work, you shouldn't buy it. Makes one yourself for less than $5.
Old Mar 1, 2005 | 05:51 PM
snuppy's Avatar
hmmm... yah, maybe we can convince mikochu to do another awesome DIY...
although, i believe in the benefits of the engine bay grounding (brighter lights/lower idle rpms)... i'm wondering how much longer it'll be until someone decides that the driver and passengers need to be grounded as well... perhaps we can beat them to the punch...
complete with a drill bit to drill straight through the firewall/bulkhead and have direct contact with the battery negative...
i'm thinking we can sell the driver/passenger grounding kit for about $149.99 each... who's with me?..
Old Mar 1, 2005 | 06:01 PM
Scott17's Avatar
StyleWagons
Group buy? I'll take 3!!!!!
Old Mar 1, 2005 | 06:32 PM
kacosta's Avatar
ive seen these on mazdas and some nissans but benefit if the guy who designed the car thought it was necc then let it be
Old Mar 1, 2005 | 06:40 PM
Huskersnow's Avatar
Read page fourteen of your Scion manual it says right there,
"when changing your muffler bearings it is recomended that at this time you also install an exhaust grounding kit"
Old Mar 1, 2005 | 07:35 PM
boilerman's Avatar
Snuppy has solved my static problem when I get out of the car. I will just use my computer ground strap to keep myself neutral.
Old Mar 2, 2005 | 10:38 PM
unlmtdndeavor's Avatar
and dont forget to recalibrate the spring rate on those bolts
DJ_FroZone
25
May 30, 2019 07:17 PM
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
TheTripleC
Jan 4, 2015 06:46 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
