Clear Corners - Rear (Altima Lens Swap)
Here's the write up - DO THIS AT YOUR OWN RISK. I'm not responsible if you make a mistake on the install.
Tools Needed:
194 bulb wire socket
93-97 Nissan Altima Rear Bumper Lens
(You can get the clear lens from www.infinitemotorsport.com or call Pujan at 817 545 4444)
Phillip Screw Driver
Electrical Tape
Molding Tape
6-pack Heineken
1. First buy the rear clear lens for the 93-97 Nissan Altima. Go to autozone/pep boys and buy the 194 bulb wire socket.
2. Unmount your rear bumper....there is one on each side.
3. Reach inside behind the stock red lens and unscrew it from the bumper.
4. Once you unscrew it, pull out the stock lens and cut the wire (cut it as close as you can to the connectors.
5. Then you connect your 194 bulb wire socket. Pop it in inside the clear lens and test it first before you mount everything back to the bumper.
6. Get your molding tape and put strips around the backside of the lens so it will stick to the bumper.
7. Voila!!! then you can drink to that.
HOPE THIS HELPS
What do you guys think????
Tools Needed:
Electrical Tape
Molding Tape
6-pack Heineken
HOPE THIS HELPS
Originally Posted by wyldkard
Probably the first in Texas. Niiiiiiiiiiiiice! It's a replacement correct?
-Z
-Z
it's not a replacement, but i don't know if you would say "conversion" since the clear lens was for another car and it fitted right in.
Thanks for the feedbacks!!!
Originally Posted by firesquare
Originally Posted by duey
spill your guts man!! which car is it from?
and where did you get that TOM'S sticker?
nice lookin camo
......AND THE SEARCH FOR THE LENS IS ON........LOL
