scion xb shocks and struts.. did i finally find some cheap!?
Old Mar 3, 2005 | 03:37 AM
1_Sick_XB's Avatar
Default scion xb shocks and struts.. did i finally find some cheap!?
Toyota echo 2000 struts and shocks made by kyb GR-2.
will these fit a 2004 scion xb for sure?
my stockers blew out 1 week after i installed my tanabe springs.. these hopefully will last longer alot longer than stockers... if they fit..
so... will they fit ?
Old Mar 3, 2005 | 05:21 AM
peabe's Avatar
Default Re: scion xb shocks and struts.. did i finally find some che
what the heck happened???
Old Mar 3, 2005 | 05:48 AM
1_Sick_XB's Avatar
no clue!
car was 1 year old. put tanabes on it and drove 200 miles. next thign i know its making noises and bouncing down the highway..
pull it apart... oil everywhere. there blown..
i need replacments.. and 600$ wont cut it.
i fond kyb gr-2's for 00-up echo's for 175 all the way around...
Anyone have proof they fit before i order these?
Old Mar 3, 2005 | 07:43 AM
heme11's Avatar
how's about a set of TRD's?
http://www.newscionparts.com/product/?id=1111
Old Mar 3, 2005 | 04:31 PM
1_Sick_XB's Avatar
i was told trd's wont handle the tanabe drop.
Old Mar 3, 2005 | 05:45 PM
TheDanger's Avatar
sell the tanabes and buy coilovers
Old Mar 3, 2005 | 05:54 PM
pdrizzle's Avatar
DeepSouth Scions
How many inches is the tanabe drop? I'm riding 2" spy drop springs and the TRD shocks/struts work great.
Old Mar 3, 2005 | 05:56 PM
TheDanger's Avatar
the same...I have tanabes and have been fine...
Old Mar 3, 2005 | 06:50 PM
1_Sick_XB's Avatar
you guys both on trd's?
where were you guys 30 posts ago!
is it true that trd's are bilstiens?
Old Mar 3, 2005 | 06:54 PM
1_Sick_XB's Avatar
i was also told the stockers work great! ahahh
seriosuly.. give me more info please
Old Mar 3, 2005 | 07:13 PM
TheDanger's Avatar
no I have stockies and they have been working fine. Have about 5k miles on them.
Old Mar 3, 2005 | 07:36 PM
pdrizzle's Avatar
DeepSouth Scions
I blew my stock struts about 8k miles after I lowered. I can't remember the manufacturer of the TRD struts, but I believe it begins with a "T"; the instructions were in Japanese. I will look behind my wheel to see if the sticker with the company name can still be seen on them. I'll let you know.
Old Mar 3, 2005 | 08:56 PM
1_Sick_XB's Avatar
how long have you been riding on the trd's ?
Old Mar 3, 2005 | 09:09 PM
Fujiz_xb's Avatar
are you serious???
can somebody confirm cuz im going that route.
Old Mar 3, 2005 | 09:19 PM
1_Sick_XB's Avatar
dead serious.. or i would have already jumped on that.
Old Mar 3, 2005 | 09:51 PM
We have a hot lava over here in the norcal that I lowered on Goldlines and trds with no problems. In fact he went to the track for fun and thought it worked ok. Thats wierd that your struts went bad. I am at 36,000 miles and my struts are still good with my RS*R springs. I have had my car for about 1.5years too. I went from Eibach to Goldline to RS*R. Still going strong on my stock struts.
Old Mar 3, 2005 | 10:40 PM
Just get the echo's they fit.
Old Mar 3, 2005 | 10:43 PM
Ed's Avatar
Ed
You don't need to use echo upper strut/shock mounts do you? I remember reading a post about it,forgot what shocks were used though
Old Mar 3, 2005 | 10:52 PM
pdrizzle's Avatar
DeepSouth Scions
Ok, if the echos fit, do they make cheap(er), performance struts/shocks for the echo?
Old Mar 3, 2005 | 11:13 PM
Lonely_Raven's Avatar
Any shock/strut that's the stock length is going to die
prematurely simply because with a 2"+ drop you are already
1/4 to 1/3 compressed. That constant compression causes
the fluids in the shocks/struts to get beaten up and foamy
which reduces their usefulness, and therefor causes them
to deteriorate faster.
Generally when you lower suspension the way we have, you
need shocks/struts that are slighly stiffer, and are designed
with a shorter travel in mind.
I used to get custom cut KYB or Koni Yellow that are
literally cut down X-Inches to match my lowering.
Not good news I'm sure, but stockies will blow. Getting the
Echo stokies is just going to do the same thing.
