Replacing Front Wheel Bearing Question!
Old Oct 18, 2010 | 08:19 PM
sn0w's Avatar
Default Replacing Front Wheel Bearing Question!
Are the front wheel bearings capable of being installed without a press?
90% positive they do, but never hurts the ask.
Old Oct 18, 2010 | 08:38 PM
2fast4aSCION's Avatar
Default hey
you can get the bearing out without a press but the new one will have to be pressed in because you will damage it beating it in.. does not cost much to get pressed in i did both of mine and it cost 25 each at a local mechanics garage..
Old Oct 19, 2010 | 06:30 PM
DezodDon's Avatar
If you are from the northeast, good luck. You need a press but to be honest all the ones I have done were seized in the knuckles.... FML.
Old Oct 20, 2010 | 12:47 AM
RyanstC's Avatar
Yes indeed you will need a press or you will be sol, you will need it to remove the hub and to re-install it as well
fur_pig
Mar 20, 2020 04:28 PM
Jordly221
Feb 13, 2019 05:29 PM
xdejablu3x
Apr 19, 2017 03:44 PM
zom6iemac
Nov 28, 2014 12:28 PM
JDMxB
13
Dec 23, 2003 04:23 AM
