120k on my car, what belts need to be replaced?
Old Nov 5, 2010 | 06:31 PM
Infamous425's Avatar
Default 120k on my car, what belts need to be replaced?
hey guys, reached 120k on my xb and i've never had any of the belts replaced. never had any problems but want to do preventative maint. which belts do i need to replace?
Old Nov 5, 2010 | 11:10 PM
racer115's Avatar
serpentine and timing belt
Old Nov 5, 2010 | 11:23 PM
N0AuTHoRiTy's Avatar
You only need to replace the serpentine belt. Your xB doesn't have a timing belt, it uses a timing chain.
Old Nov 5, 2010 | 11:59 PM
padillaXA's Avatar
off topic but are the tc's chain too, or belt?
Old Nov 6, 2010 | 12:04 AM
tC's are chain also.
Old Nov 6, 2010 | 12:59 AM
Zman's Avatar
How much do they charge to replace the serpentine belt usually?
Old Nov 6, 2010 | 01:12 AM
padillaXA's Avatar
i got mine done for 50bux including the belts,tax,and work, but its much cheaper to do your self if your up to it, just be careful for the camshaft position actuator thing! the first time i had to replace mine i DIY'd and busted it! turned a $15 replacement to a $120 job.
Old Nov 6, 2010 | 04:47 AM
tc-guy's Avatar
there is two belts on the xb. one for the a/c compressor, waterpump and alternator. one for the p/s.
Old Nov 6, 2010 | 06:28 PM
Zman's Avatar
Which belt does a lightweight pulley attach to?
I'm not sure about some of the internals of the engine, just wondering if it would be easier to upgrade since the belts are being removed already.
Old Nov 7, 2010 | 04:22 PM
padillaXA's Avatar
depends? you can get a lightweight pulley for almost every application, you can get underdrive pulley sets, just the crank pulley, or alternator, it could be either belt depending. i think we need a lil more specifics cuz theres 5 different pulleys.
but if this is your DD id say leave them be if there not broken/bent/worn. SOME aftermarket pulleys can cause unfavorable side effects, like not enough power to the alternator or overly stiff steering. the only real up to having lightweight or underdrive pulleys is reducing drag and moment inertia, the HP gain is almost negligible in our cars, maybe 1-3HP max.
Old Nov 7, 2010 | 05:12 PM
thanks guys!
Old Nov 17, 2010 | 08:28 PM
mrsocks's Avatar
Yes, The '06 xB has 2 belts as stated above. All internal is chain. Just got back from dealer here in AZ and they wanted $175.00 to do belts (2). Got decent Dayco belts at Pep Boys for $35.00 and will install myself as there seems to be a bit of room in there. Any "sticky's" or step-by-step on this, or is that even needed?
As always....Thanks to all!!!
Socks
Old Nov 18, 2010 | 07:18 AM
brainneeded_'s Avatar
Socks
wrd. i need to do this soon too, i have about 98k miles.
Old Nov 21, 2010 | 07:22 PM
meiji_choco's Avatar
the DIY is here:
http://www.clubxb.com/forums/f14/diy...nfo-30515.html
Old Nov 24, 2010 | 04:20 AM
thanks!!!
Old Jan 9, 2011 | 07:21 PM
archangel's Avatar
I bought the same dayco belts, same part #'s as well, but mine say poly rib not poly cog like in the example from clubxb? how can you have two different belts with the same part number but are different belts!!!!
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
mdhyre
Dec 7, 2014 12:52 AM
vitkh
Nov 30, 2014 02:27 PM
tC_Normo
Oct 22, 2003 07:20 PM
