Cell Phone Mute Function
Old Mar 8, 2005 | 04:32 PM
douglaing's Avatar
Default Cell Phone Mute Function
I put a new Motorola Bluetooth hands free kit for my cell phone in my XB and wanted to mute the radio when the phone was in use and or when it rang. All hands free kits wired and wireless have a wire to mute a radio if supported.
My stock pioneer radio did not have this function documented, well I took the radio apart and found that the un-used pin on the smaller connector was the mute function.
I was not able to find a proper metal socket/pin to put into the connector so I took a #14 wire stripped off about 1/4 inch folded it back against itself to make a 1/8" doubled up end and forced it into the blank hole to make contact with the radio's pin then zip tied it to the wire next so it would not work it's way out. I then connected the end of this wire to the mute wire from the cell phone hands free kit and it works great.
My radio is the single CD stock pioneer that is used in the 2005 XB XA & TC.
I do not know if this works in the 6 cd version but if it has the same missing wire in the smaller connector it probably would. To test just ground that pin on the radio's connector if the radio mutes then comes back when removed you have it.
This is not documented by Toyota and I am not responsible if it kills your radio but it worked for me. I have been using it for about a month now, I use my XB for work and am on the phone on and off all day long.
Old Mar 8, 2005 | 04:41 PM
engifineer's Avatar
Very cool info! Thanks!
scionlife's Avatar
Founder
Photos anyone?
Old Mar 8, 2005 | 09:20 PM
Speedpunk's Avatar
Excellent info! I've been wondering the same thing, thanks for taking the guess work out of it!
Old Mar 9, 2005 | 05:53 AM
CRxB's Avatar
good info all you need now is a photo so it can be moved to tech
Old Mar 9, 2005 | 06:03 AM
XBman's Avatar
its in tech.... pix would be sweet
Old Mar 13, 2005 | 01:22 AM
douglaing's Avatar
Default Photo of connector
The next time I have the radio out I will get a photo of the connector, but It's easy:
There is only one missing wire, One conncetor is full and the other has one wire missing. The blank hole is the one you want.
I have taken my stock radio out now and replaced it with a Pioneer DEH-P6700MP, Pioneer Sirius tuner and the Crutchfield XB face mount kit. Sounds great and I now have Sirius working.
Old Mar 15, 2005 | 08:35 PM
teamkasnomas's Avatar
You rule. Thanks for the R&D!
Old Mar 18, 2005 | 03:42 PM
TheFly's Avatar
Which Motorola Hands Free kit did you get? That's my #2 planned addition to my xA when I get it.
Old Mar 21, 2005 | 10:13 PM
oceasar's Avatar
Default Anyone looking for 6 disc SCION radio
i have one available in California
Old Apr 13, 2005 | 04:50 PM
bluebb05's Avatar
will this work with any hands free kit
Old May 22, 2005 | 06:02 PM
05BoX's Avatar
interesting... anyone have info on the rest of the pins on the stock radio?
Old Jun 8, 2005 | 11:43 PM
Amerhicka's Avatar
Default Wiring diagram including radio wire colors
I can't vouch for it's accuracy, but I found this wiring breakdown at the12volt.com:
http://www.the12volt.com/installbay/...15628&KW=scion
Old Aug 8, 2005 | 01:18 PM
billyng's Avatar
Default Re: Cell Phone Mute Function on Stock 2005 Radio xB/xA/tC
Hey, douglaing. I just installed a Sony Ericsson HCB-30 Bluetooth handsfree car kit to my xB with following your instructions. It is working so well. The music will be cut when there is a incoming call. Very ncie, so nice, thanks!
Old Aug 11, 2005 | 09:01 PM
itstdt's Avatar
Can this be used on a bluetooth headset? just wonder...
Old Aug 12, 2005 | 03:30 PM
billyng's Avatar
No, I don't think so. In fact, people use HCB-30 because they don't want to wear the headset. Instead, using the speaker to output the voice. If you don't want the passengers to hear your phone conversation, HCB-30 is not suitable for you.
Old Aug 12, 2005 | 04:32 PM
itstdt's Avatar
oh... ok... thx... i am gonna stick with my Jabra BT headset
Old May 3, 2006 | 08:26 PM
Djicey702's Avatar
This post makes me wanna buy a Blue tooth phone now..
Old May 4, 2006 | 12:44 PM
PrivateTucker's Avatar
I'm looking into the Parrot CK3100. It can be found for $150 on Froogle. It seems to be a nice unit.
Thanks to this Tech article, I can do it myself now.
Old Feb 8, 2007 | 12:46 AM
MayJ612's Avatar
photos would be nice
