Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Suspension & Handling
Register Forgot Password?
Reply
Old 01-12-2011, 05:05 AM   #1
The_Jimmer
The_Jimmer's Avatar
The_Jimmer 37/M
Default Warped rotors
At about 30k I noticed pulsation in the brakes so I ran the rotors through the lathe and started running smooth again. Up until that point I had been letting the dealer rotate my tires and figured they just weren't torquing the wheels properly so I started rotating on my own. 35k miles later and its time for new pads, and the pulsation is back. Has anyone else noticed this issue with the xD?
The_Jimmer is offline   Reply With Quote
Old 01-12-2011, 01:27 PM   #2
Basebllstar
Basebllstar's Avatar
Basebllstar 23/M
Send a message via AIM to Basebllstar
It happens man. I don't see what tire rotations have to do with it.
http://reviews.ebay.com/What-causes-...00000005242298
06' SW tC
Basebllstar is offline   Reply With Quote
Old 01-13-2011, 12:46 AM   #3
libima
libima 36/M
If you over torque the lug nuts it can cause the rotor to warp. That is what the tire rotation has to do with it.
As for the problem with warped rotors, I don't know what to say. I'm a little over 100K miles and haven't had any problems with the brakes at all.
libima is offline   Reply With Quote
Old 01-13-2011, 12:50 AM   #4
TscionC05
TscionC05's Avatar
TscionC05 21/M
my g/f has the xD, it has 60k on it and still no shake while braking
TscionC05 is offline   Reply With Quote
Old 01-13-2011, 05:38 AM   #5
The_Jimmer
The_Jimmer's Avatar
The_Jimmer 37/M
Maybe just a bad run on rotors then and I got a bunk set...
Uneven torque on the lug nuts is the most common cause of brake rotor runout actually. A couple thousandths of an inch is all it takes to start feeling pulsation through the pedal as you apply the brakes. I am very adamant about using torque sticks at very least when putting wheels back on cars. It bugs the hell out of me when I see other technicians tightening the lugs on customers' cars with a bare impact gun.
Old 01-13-2011, 06:02 AM   #6
TscionC05
TscionC05's Avatar
TscionC05 21/M
they dont care, its not theirs lol
Old 02-20-2011, 08:57 AM   #7
Palomino0513
Palomino0513 26
OK my XD has about 35k on it and I have been hearing grinding noises when I brake. I know nothing about brakes so can someone help me out. First I need to know what bad pads or rotors or boots look like in order to replace them.
I don't understand any of the vocab you people use lol...
Palomino0513 is offline   Reply With Quote
Old 02-20-2011, 04:42 PM   #8
TscionC05
TscionC05's Avatar
TscionC05 21/M
^all it is is a metal plate behind your rotor that is rubbing on the rotor while braking, just bend it back a little bit
Old 02-21-2011, 02:00 AM   #9
CXTKRS1
CXTKRS1's Avatar
CXTKRS1 27/M
17K (alot of miles right) and no problems here.
CXTKRS1 is offline   Reply With Quote
Old 02-21-2011, 05:00 AM   #10
mcbrew
mcbrew's Avatar
mcbrew 37/M
55,000 miles and there is still some meat left on the pads... rotors are fine, too. I just took a look at them while I was flushing the brake fluid. By the way, a brake fluid flush should be done about every two years regardless of mileage. You don't want water in the brake fluid to corrode the caliper pistons. When this happens, you get sticky calipers, which will result in uneven (and faster) pad/rotor wear, more heat (which could lead to warping of the rotors), and eventually will completely stick a caliper.
Just a friendly reminder!
-McBrew
2011 Subaru Outback 2.5i Premium
2009 Scion xD - SOLD
FOR SALE: xD cabin air filter, (3) xD oil filters, Assenmacher oil filter wrench for xD. (all filters are OEM)
FOR SALE: xD original shift boot for 5-speed. New condition.
mcbrew is offline   Reply With Quote
Old 09-04-2011, 03:42 AM   #11
Tweedwon
Tweedwon 41/M
Andrew Tweedlie
Default Brake & Rotor Replacement
My XD has 50k and it's getting time to replace the pads! Brakes are great! But, more is always better... Has anyone upgraded their brakes? I did the Moonshiner 28 (103mi of mountian road twisties) and The Dragons Tail (318 hair pin turns...in 11 miles!) no brake fade or warpage!!
Tweedwon is offline   Reply With Quote
Old 09-04-2011, 04:10 AM   #12
Nateson
Nateson's Avatar
Nateson 32/M
Send a message via MSN to Nateson
Nice, I wish they didn't have all the speeding devices up on the dragon, but I guess it still would be fun.
I removed my windshield wipers and now I don't get parking tickets. Suck it. --- YUCKYBOT
Nateson is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2008, 2010, brake, issue, rotate, rotation, rotor, rotors, scion, tc, uneven, warp, warped, wear, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
