Register Forgot Password?
Reply
Old 01-26-2011, 01:06 AM   #1
TinmanTC
TinmanTC's Avatar
TinmanTC 29/M
Default How do I replace brake tail light bulb?
Tried googling but end up with 10000 led/third brake light bulb matches.
All i wanna do is replace my burned brake light. I believe its a 7443 bulb.
What do I do?'
thanks
TinmanTC is offline   Reply With Quote
Old 01-26-2011, 01:11 AM   #2
draxcaliber
Moderator
Moderator
draxcaliber's Avatar
draxcaliber 28/M
Send a message via AIM to draxcaliber
check you're owner's manual?
never had to do it since mine have never burn out, but i imagine you open the hatch, pop over that little cover on the inside of the corner behind the taillight and twist the dead bulb out, and replace it.
it is almost as hard as...changing a lightbulb.
Takumi is a Japanese character that symbolizes a broader dimension than quality, a deeper process than education, and a more perfect method than persistence.
draxcaliber is offline   Reply With Quote
Old 01-26-2011, 04:04 AM   #3
Spicy_McHaggiz
Spicy_McHaggiz's Avatar
Spicy_McHaggiz 26/M
Owners manual tells you how, but in case thats to simple or hard, here you go.
1) Pop the rear hatch
2) In the corner where the back of the tail lights are you see 2 covers with plastic tabs. Pull those tabs out and the entire panel comes out. (yes the fuzzy things)
3) Twist and pull the correct socket that corresponds with that in which is burnt out.
4) Reassemble the same way you put it together.
He's such a dick that his car even wanted out so it drowned itself.
TROOOOOF. My "Lesbaru" is slow though, only 13's in the 1/4 fml. <That's SUPER PERFORMANCE (Right Hayfail?)
Spicy_McHaggiz is offline   Reply With Quote
Old 01-26-2011, 04:09 AM   #4
MANiAK
MANiAK's Avatar
MANiAK 22/M
I believe he's talking about the trunk/3rd brake light
EDIT: my bad, you're right -.-
MANiAK is offline   Reply With Quote
Old 01-26-2011, 06:10 PM   #5
TinmanTC
TinmanTC's Avatar
TinmanTC 29/M
thanks
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2005, brakelight, bulb, bulbs, change, changing, light, rear, replace, replaced, scion, stop, tail, tc, xa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
