Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 02-16-2011, 08:55 PM   #1
ToolishTc
ToolishTc 33/M
Default question about transmission drain and fill plugs
are there washers on these and if so do they usually need changed when i change my gear oil? are they they same size as the oil plug?
thanks
ToolishTc is offline   Reply With Quote
Old 02-16-2011, 09:24 PM   #2
Syldrin
Syldrin's Avatar
Syldrin 28/M
Syldrin
Send a message via AIM to Syldrin Send a message via MSN to Syldrin
they are not the same size not even close. as far as washers i cannot remember if there is a crush washer on them
Dezod Alpha series and more to come
Syldrin is offline   Reply With Quote
Old 02-16-2011, 09:30 PM   #3
GammaTNT
GammaTNT's Avatar
GammaTNT 35/M
Send a message via AIM to GammaTNT Send a message via MSN to GammaTNT
there are washers on the drain and fill plugs. Don't not over tighten them. One member was leaking tranny fluid after over tighten the drain plug. sorry i don't know the size.
PM me if you need Eclipse MDV-82D
GammaTNT is offline   Reply With Quote
Old 02-16-2011, 09:33 PM   #4
SquallLHeart
Super Moderator
SuperMod
SquallLHeart's Avatar
SquallLHeart 30/M
Send a message via AIM to SquallLHeart
do not need to be changed, and definitely not the same size as the motor oil drain plug
please??
the source of original LED ideas - swap expert - parts available Become a fan! LED-Headz
need 2nd GEN tC info? disassembly? questions? i got most of it down.
need help? call me: 408-905-7769
me like:
Doctor Isotope | PrecisionMuffler | 365motorwerks | LEDmod.com(custom Gaugefaces)
SquallLHeart is offline   Reply With Quote
Old 02-21-2011, 09:02 PM   #5
ToolishTc
ToolishTc 33/M
thanks for the replies. as soon as the weather breaks i'll put your info to use.
Old 04-08-2011, 12:15 AM   #6
ToolishTc
ToolishTc 33/M
an update, and a couple of notes
the drain and fill plugs are both 24mm, and make sure you use a very shallow socket or you will not be able to fit a ratchet on the drain plug.
when you open the drain plug, be prepared for a rush of gear oil. it comes out with a lot of force and flies into the control arm and splashes everywhere.
i filled up with a pump and the fill hole on the side of the tranny to avoid removing the reverse sensor. overall, it was a really easy job.
Old 04-25-2011, 01:06 AM   #7
Tc3340
Tc3340 26
How much fluid will I need when I do this myself? I'm going to Change it as I dont think it's been done since the car was brand new.
Tc3340 is offline   Reply With Quote
Old 05-10-2011, 05:37 PM   #8
BadDudeTC3
BadDudeTC3's Avatar
BadDudeTC3 33/M
You'll need 4 quarts of fluid when filling the transmission. Are you Auto or Manual?....Reason I ask is because I just changed my Auto trans fluid and I had to use a 10mm hex head to unscrew the drain plug....I'm sure its a lot different on a manual. Like the previous post stated, be ready for oil to gush out as soon as turn the drain oil! Also I had to go to the dealer and pick up the WS type transmission fluid because that's what my 07 tC used.
Mad Sciontist Chicago
Custom Turbo kit....to many mods to list
BadDudeTC3 is offline   Reply With Quote
Old 05-10-2011, 07:27 PM   #9
Tc3340
Tc3340 26
I'm manual.
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
05, 07, 2005, drain, fill, fluid, gear, needed, oil, plug, scion, size, tc, tool, tools, transmission, unscrew, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
