Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 02-24-2011, 01:57 PM   #1
uncblue07tc
uncblue07tc's Avatar
uncblue07tc 29/M
Send a message via AIM to uncblue07tc
Default Check Engine Light Just Come On
Hey all. I cleaned up my tC about 2 months ago and have only been driving it on short trips around town (not that it would matter) but this morning my check engine light came on. I crunk up the car, went inside to let it warm up, and when I came back out and started out of the driveway the light came on. I don't think it would matter, but my low tire pressure light and maintenance light (need to change oil) was on already, before the check engine light came on. The car drives fine, nothing odd going on. I'm going out in a few mins to take my gas cap off and re-tighten it, hoping that may be the culprit. Can anybody shed some light on this for me, some suggestions? Could this be a sensor that has went bad? The car has about 66,500 miles on it. Thanks in advance!
Yesterday is history! Tomorrow is a mystery! Today is a gift, that's why we call it the present!
uncblue07tc is offline   Reply With Quote
Old 02-24-2011, 02:05 PM   #2
beandip007
beandip007's Avatar
beandip007 31/M
Get the code read with an obdII reader, prolly evap system, but this can't be determined with out the code.
******DEZOD HEADER******
^^^^^Come get some!^^^^^
Even in the future nothing works!
beandip007 is offline   Reply With Quote
Old 02-24-2011, 02:12 PM   #3
uncblue07tc
uncblue07tc 29/M
Would ya'll recommend I take it to Advance Auto or Auto Zone and let them hook up a code reader? I've heard of ppl doing this in the past and it seems like a short time afterwards their cars always have more issues that they'd never had before having the code reader hooked up.
Old 02-24-2011, 02:31 PM   #4
beandip007
beandip007's Avatar
beandip007 31/M
to read the code is in NO way ever going to effect you getting more check engine lights. It is a free service to get the code so you can fix the problem, and turn off the light. More lights will come on, get the code fix the problem.
Old 02-24-2011, 02:50 PM   #5
vettereddie
Moderator
Moderator
vettereddie's Avatar
vettereddie 32/M
Autozone won't turn off the check engine light for you, it's on for a reason and they don't want to risk liability. They will however, give you the code so we can possibly help you torubleshoot this. It could be as simple as the MAF sensor being dirty, a bad PCV valve, or a loose clamp on the intake. Don't take it to the dealer, they will charge you an hour of labor at $100 for the same exact thing to read the code. To buy a reader only costs $65.
vettereddie is offline   Reply With Quote
Old 02-24-2011, 02:54 PM   #6
beandip007
beandip007's Avatar
beandip007 31/M
I don't know autozones policy, but at o'rieillys they take my drivers license and give me the scanner I check the code and it gives the option to turn off the light. Easy.
Old 02-24-2011, 03:20 PM   #7
vettereddie
Moderator
Moderator
vettereddie 32/M
Yeah, I guess if they let you do it yourself it absolves them from liability. Maybe some Autozones do that too, I ended up just buying a scanner to save on trips, lol.
Old 02-24-2011, 03:26 PM   #8
beandip007
beandip007's Avatar
beandip007 31/M
Yep, scanguageII baby! I have check engine lights from hell. Header, bad gas cap etc.. Oh well car runs fine.
Old 02-24-2011, 03:42 PM   #9
uncblue07tc
uncblue07tc 29/M
I went to my local Advance Auto. The reader said something about the emissions system having a leak. I took my gas cap off, tightened it back, they turned off the light and (of course) didnt come back on yet. It was only like 2 miles from Advance to where I am now. I hope the light stays off.
Old 02-24-2011, 03:57 PM   #10
SierraRomeoAlpha
SierraRomeoAlpha's Avatar
SierraRomeoAlpha 26/M
Go to Oreilly Auto Parts. They pretty much rock..
SierraRomeoAlpha is offline   Reply With Quote
Old 02-27-2011, 09:49 AM   #11
rougenite
rougenite's Avatar
rougenite 27/M
Send a message via MSN to rougenite
Idk....went to oreilly and asked for a torque wrench up to 175 ft lbs....dude brought me an inch pound one and tried to tell me it was up to 960.....zzzzzzz lol
rougenite is offline   Reply With Quote
Old 02-28-2011, 02:10 AM   #12
JacobYamaha23
JacobYamaha23's Avatar
JacobYamaha23 20/M
JacobYamaha23
mine coded 465 something bout emission control something what does this mean....
JacobYamaha23 is offline   Reply With Quote
Old 02-28-2011, 02:26 AM   #13
XIEmperorIX
XIEmperorIX's Avatar
XIEmperorIX 27/M
XIEmperorIX
Send a message via AIM to XIEmperorIX
I believe it has to do with your O2 sensor but I am not sure
2007 FM tC auto *past*
2011 WR Blue WRX 5dr *present* :D
XIEmperorIX is offline   Reply With Quote
Old 02-28-2011, 02:28 AM   #14
JacobYamaha23
JacobYamaha23 20/M
JacobYamaha23
idk somebody told me maybe it might b the egr valve going bad but im not sure either thats y i got on here and asked
Old 02-28-2011, 01:26 PM   #15
vettereddie
Moderator
Moderator
vettereddie 32/M
Try to do a web search for P0465. Here's what I got back on ScionLife:
ODBII Codes
P0465 is Purge Flow Sensor Circuit Malfunction, so I'm guessing it's something to do with the purge flow sensor. I'm guessing there's a charcoal canister on the tC where the sensor would be located, I've got an xB so not 100% familiar. It's usually by the gas tank underneath the car, a little balck box with some hoses and an electrical connector. I beleive if you overfill the gas tank a lot it might contaminate the canister. Not sure if it can be dried out or if a new one would be needed.
Old 02-28-2011, 03:46 PM   #16
beandip007
beandip007's Avatar
beandip007 31/M
I get those codes all the time, it's your gas cap, get a new one and the codes will go away, we have to change the dang things every 2 years.
Old 02-28-2011, 05:21 PM   #17
SoccerBoy_AP
SoccerBoy_AP's Avatar
SoccerBoy_AP 31/M
Send a message via ICQ to SoccerBoy_AP Send a message via MSN to SoccerBoy_AP
Quote:
Yeah ScanGaugeII!!!
It's a relativly inexpensive tool that does more then codes.
I constantly monitor water temp, intake temp, mpg's and voltage with mine.
Should you ever pop a code... bingo you can find out immediatly and bypass the auto stores all together...
2006 - Scion tC - TRD S/C
55mm Pulley @ ~10psi
(outdated dyno @ 65mm)
207hp/188tq @ 7.7psi
SoccerBoy_AP is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2006, auto, bad, car, check, dealership, engin, engine, light, oreillys, pcv, scion, tc, turn, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
