2011-____ [ANT20]
I plan to take MY TC2 to the DRAG STRIP..
Old Feb 26, 2011 | 09:45 PM
mdiluxe's Avatar
Smile I plan to take MY TC2 to the DRAG STRIP..
I am going to take my car to the track either March 5th or 6th, not sure yet or date or track. I might go my local track on Saturday the 5th, or either I might go to MIR, on the 6th only. I am not doing both. But with that being said, I hope to run at least 15.1-15.5 @ 87.x-92.x mph. It’s going to be hard to get advice for the TC’s from my fellow buddies, since not a lot of people race them. So, I have to experiment and try to find the best rpm to launch at. I say 2000rpm. Any suggestions? Since the car runs out of steam around 5800-6000rpm, that’s where I plan to shift at. Also weather and track conditions will factor in, so I will adjust. I plan on running the car 3 times, if they are not packed with cars.
  • With traction Control
  • Without traction Control(completely off)
And before I take my car to the track, I have to change the transmission fluid. A must for everyone, but not everyone does this. Bad mistake! Since the tire pressure recommend for the 2011 Scion TC is 33PSI for the FRONT, and 30PSI for the REAR. I will try those PSI’s on the first run. On the second and third, I will change it as long as I get those amount of runs and depends on track prep, weather etc(cold, warm, etc). I plan to keep the car stock no weight reductions (no removing the spare, back seats, passenger seat, etc). Yes removing 100lbs should improve times by one tenth of a second blah blah. LOL . Not going to happen at least for now. Oh yea for gas, still 87, and I going plan on putting ¼ or so in it. I will weigh the car, and hopefully have some footage for your guys and gals.
Old Feb 27, 2011 | 03:12 AM
JMANTC's Avatar
Why 87 gas?!?!
Why launching at only 2000 rpm?
I hope you plan on shifting at 6000 rpm!
How do you adjust to weather conditions?
I'm looking foward to see if you actually make the 15 sec range................
Old Feb 27, 2011 | 04:55 AM
MightyP's Avatar
I look forward to seeing what kind of numbers you pull.
Old Feb 27, 2011 | 08:45 PM
Onebit's Avatar
I'm going to my local track with my tc2 in April, good luck and let me know your results!!!
laforze
12
Feb 16, 2016 12:50 AM
brett561tc
Sep 15, 2015 06:33 AM
Threequalseven
Aug 26, 2015 04:24 PM
nightwitch
Jul 14, 2015 01:58 AM
Codebender
Jul 13, 2015 07:05 PM
