Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 05-12-2011, 11:29 AM   #1
raddevon
raddevon 30
Question Engine braking effect on fuel economy?
I just bought a 2006 xA with manual transmission, and I want to squeeze the best fuel economy possible from it. I've always been taught that engine braking is a good thing because it saves the brakes, but I'm concerned about the impact on my mileage. Does anyone know if this makes a difference? Is it preferable to use engine braking, or should I be using the actual brakes in neutral?
raddevon is offline   Reply With Quote
Old 05-12-2011, 12:18 PM   #2
BeloZero
BeloZero's Avatar
BeloZero 28/M
engine braking is good on the freeway, esp going down steep grades. not sure about the MPG effect though (im sure its minimal). need to be careful if its wet or slippery out though cause if you engine brake to hard and send the RPMs up too fast, you can start skidding.
BeloZero is offline   Reply With Quote
Old 05-12-2011, 01:54 PM   #3
Improbcat
Improbcat 35/M
Send a message via AIM to Improbcat
There is two different engine braking scenarios:
Slowing yourself on steep downhills. In this case using engine braking to keep the vehicle speed down and save from overusing & overheating the brakes makes good sense.
Slowing/Coming to a stop in normal driving conditions. In this case downshifting to slow the vehicle doesn't make much sense, you are using your clutch ($500+ replacement cost) and transmission($2000+ replacement cost) to save wear on your brake pads ($50replacement cost). HOWEVER when your xa is coasting and in gear with the RPMS above ~1000 the injectors shut off and you are using zero gas. So what makes the most sense is to coast down in whatever gear you are already in, using a combination of the engine braking in that gear and the actual brakes to slow you, and putting the clutch in when the RPMS get to about 1000. If you combine this with watching traffic ahead for slowing/stopping traffic so you can start coasting as soon as possible you can get the whole time you are coasting in gear "free", and use no gas.
Hopefully that made some sense, I haven't finished my coffee yet.
Think inside the Box!
Improbcat is offline   Reply With Quote
Old 05-12-2011, 02:27 PM   #4
raddevon
raddevon 30
Improbcat: That makes perfect sense. I will start putting that into practice. Thanks!
Old 05-12-2011, 09:52 PM   #5
shadowler
shadowler 23
I perfectly agree with the cost factor of what this jazz cat has to say. It is not worth it putting the stress on your transmission if you are not super experienced with this type of braking to begin with. I advise not to engine brake at all and just brake normally.
Do not be too nitpicky on the mileage with this kind of method, the gain is minimal and just not worth it. Drive normally and our cars will long life ahead.
shadowler is offline   Reply With Quote
Old 05-15-2011, 07:05 AM   #6
ajcadoo
ajcadoo's Avatar
ajcadoo 20/M
ajcadoo ajcadoo ajcadoo ajcadoo
Send a message via AIM to ajcadoo Send a message via Skype™ to ajcadoo
Well, when you let up on the gas, it doesnt shut off the engine entirely, gas is still coming into the engine, but at an idle rate. For my xb, I idle at about .20gal/hour and when im traveling at 65 without the gas on, I get the same .20gal/hour.
2006.5 Scion xB ['__'`,-, Towster Mods List
DC Headers | Fujita SRI | TRD Exhaust | Hotchkis Rear Sway Bar | 8000K HID JDM Fog Lights
15" MB Wheels: Drifter Gloss Black | IPCW Euro LED Tails | IPCW Projector Fronts with Angels
FlowLighting Blaze 7 Underglow | 12" Kenwood Sub w/ 1800W Class D Amp | Neo iPhone Adapter | LED Dome
JDM Window Visors | Rostra Cruise Control | Aftermarket Front Bumper Grilles | eTrailer.com Custom Tow Hitch Kit
ajcadoo is offline   Reply With Quote
Old 05-15-2011, 08:01 AM   #7
RS1_2047
RS1_2047's Avatar
RS1_2047 18/M
keeganemdent
Send a message via AIM to RS1_2047
you should really be using both when you are coming up to a stopped car or a light. just don't send your RPMs past like 4000 and you should be okay. engine braking should be a habit so i your brakes ever fail, you'd be slowing down the car and minimizing damage. as for gas mileage it has almost no effect. if you want to save gas just try to keep the car in the tallest gear possible.
Quote:
Originally Posted by crush02342002 View Post
lmao...what is going on here...we tell people to search and now its biteing us in the ace...
Quote:
Originally Posted by so lowww View Post
your really shouldnt jerk while accelerating. theres a time and place for that. while driving is just too dangerous. or at least have your passenger help you out
real men drive stick
RS1_2047 is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2006, 2011, boost, brake, braking, consumption, economy, effect, engine, fuel, good, mileage, scion, scionxa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
