deeper dish in rear...
Old Mar 17, 2005 | 12:41 AM
xlethal's Avatar
Default deeper dish in rear...
what is the deepest size and offset you can have in the rear without modification, im looking to get a look similar to this.... Not this outrageous but as close as possible
Old Mar 17, 2005 | 01:48 AM
EMU's Avatar
EMU
you can put a 9.5 inch in the rear offset should be +20 should be fine
Old Mar 17, 2005 | 01:57 AM
xlethal's Avatar
will that still tuck?
Old Mar 17, 2005 | 02:03 AM
EMU's Avatar
EMU
it'll be close might have to roll the fender a little
Old Mar 17, 2005 | 02:09 AM
tinybigrig's Avatar
you may need a few degrees of camber as well, just be prepaired to be flipping tires from side to side every month or so to get better wear out of them
brent
Old Mar 17, 2005 | 02:10 AM
stankubrick's Avatar
if you stretch a 215 over the 9.5 and maybe 3 degree camber, you can get the tire to tuck and have the rim lip flush. You'll probably only need to roll the fender flat.
Old Mar 17, 2005 | 02:11 AM
EMU's Avatar
EMU
scratch that!!! offset should be +25 i remember formula2 had some 18x9 w/ +20 offsets it was over the fender by some here check it out
Old Mar 17, 2005 | 02:13 AM
EMU's Avatar
EMU
get some camber plates also pm MyBox
Old Mar 17, 2005 | 02:46 AM
yup and yup , he's running 9.5's in the back , camber plates help alot .
Old Mar 17, 2005 | 02:47 AM
No, I think +20 would be fine cause the camber plates will bring in the top of the wheel a little. I guess it depends on how flush you like it, though. Oh, and you gotta have coilovers or air...you have to go *low* to make it look right.
Old Mar 17, 2005 | 02:49 AM
correct sir. I told you to get coilovers rico , lol.
Old Mar 17, 2005 | 03:03 AM
Fujiz_xb's Avatar
dat xb looks haaawwwt. .
Old Mar 17, 2005 | 03:22 AM
xlethal's Avatar
so is it 2 degree camber plates 18x9.5 +20 offset?
or is it 2 degree camber plates 18x9 +20 offset?
or is it 2 degree camber plates 18x9.5 +25 offset?
or is it 2 degree camber plates 18x9 +25 offset?
Old Mar 17, 2005 | 03:33 AM
Worry about getting the wheels first >hahaha< After that, put em on and adjust accordingly....good luck
Old Mar 17, 2005 | 03:36 AM
Yeesh, I'm slow huh. I ditched the Tein Basics idea and am now considering HKS or air...after that, I am done!! (No more Philly, I am staying!)
Old Mar 17, 2005 | 04:32 PM
xlethal's Avatar
18x9 +20 offset, thats what im going for, ill get back with you guys when they get here, THANKS for all the help
Old Mar 17, 2005 | 05:18 PM
Yeah boy , now if/when u get coilovers I'd love to install them , I can install air too but it'd take awhile longer , glad to hear yer staying here man. I was gonna miss ya!!!
Old Mar 17, 2005 | 05:19 PM
Should work fine with 2 or 3 degrees.
nightwitch
Jul 14, 2015 01:58 AM
TryFailRepeat
Jun 18, 2015 11:47 PM
stenger
Jun 10, 2015 05:05 AM
AstraXtreme
Feb 25, 2015 04:24 PM
flat__tires
14
Mar 1, 2005 05:43 AM
