Go Back   Scionlife.com » Scion xB 2nd Gen » Scion xB 2nd-Gen Owners Lounge » Scion xB 2nd-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 05-18-2011, 06:36 PM   #1
HypnoticTealMica
HypnoticTealMica 65/M
Default 3rd Bad Ignition Coil
xB 2008 purchase 02-15-08. 39,000 miles currently.
First 2 coils replaced under warranty along with engine wiring harness.
3rd coil/labor I paid for 05-13-11.
This is starting to look like a chronic issue with my car.
Dealer says no TSB on xB coils though I found this later...
NHTSA: Action Number: 10030353 Service Bulletin Number: 268778
  • Report Date:
    May 21, 2009
  • Component:
    Electrical System
Summary: Scion: some vehicles may exhibit a M. I. L. On condition with diagnostic trouble codes (dtcs) p0351, p0352, p0353 and/or p0354 (ignition coil primary/secondary circuit) stored in the engine control module/ecm (sae term: power control module/p
Dealer also said coil pack was "redesigned recently".
Does TSB cover xB electrics beyond 36K?
Anyone else have an xB burning through coils?
HypnoticTealMica is offline   Reply With Quote
Old 05-19-2011, 06:45 PM   #2
jrincon17
jrincon17's Avatar
jrincon17 42/M
call scion corp
Still stock xb gen2 BSP
jrincon17 is offline   Reply With Quote
Old 05-21-2011, 11:24 PM   #3
r2d2michael
r2d2michael's Avatar
r2d2michael 24/M
i just took mine in today for that same issue. they are replacing all 4 coils and spark plugs. 2009 scion xb 31k
r2d2michael is offline   Reply With Quote
Old 05-26-2011, 08:06 AM   #4
ScionFred
ScionFred's Avatar
ScionFred 54/M
^^^ Obviously not the same problem^^^
14.12 @ 97.6 mph
ScionFred is offline   Reply With Quote
Old 05-26-2011, 02:44 PM   #5
r2d2michael
r2d2michael 24/M
Quote:
the dealer told me it had somthing to do with the TSB. only 2 had failed they replaced all 4 just incase.
Old 05-26-2011, 05:07 PM   #6
ScionFred
ScionFred's Avatar
ScionFred 54/M
The TSB applies to early 2008 XBs only. Mine is affected but all 4 coils are still good after 50k.
14.12 @ 97.6 mph
Old 05-26-2011, 07:29 PM   #7
r2d2michael
r2d2michael 24/M
Well if I did break them I won’t do it again. The tsb for the squeaking dash was also for 2008(good chance I’m wrong) yet my dash squeaked like hell
I do agree that the tc cover isn’t the best choice on the xb. But in a pinch you could get it to work.
Old 05-27-2011, 08:20 AM   #8
ScionFred
ScionFred's Avatar
ScionFred 54/M
We all make mistakes but the important thing here is to provide accurate info to others who may attempt the same thing. It appears that one can use one of the 2 available TC valve covers on a XB2 by carefully shimming the coil packs or possibly switching to TC coil packs. Do you know what model year your TC VC is off? That could be important considering that there are 2 different TC VC's. Now that you've shimmed the coil packs and they seem to be working with your TC VC, can you tell us what size shims are needed? If all's that needed is a few washers this info could be very useful to others.
14.12 @ 97.6 mph
Old 05-28-2011, 11:21 PM   #9
r2d2michael
r2d2michael 24/M
i think it was a 2007. ill measure it soon to know for sue. i think its only a few washers stacked. like 3 or 4 less than a 1/4" i think.
Old 05-29-2011, 03:45 AM   #10
TrevorS
TrevorS's Avatar
TrevorS 13/M
Quote:
Thanks! Information that clarifies rather than obfuscates is much appreciated! Again -- thanks !
TrevorS is offline   Reply With Quote
Old 05-29-2011, 04:22 AM   #11
ScionFred
ScionFred's Avatar
ScionFred 54/M
Cool. Info like this can really help the next guy who may want to try this valve cover swap. AFAIK you're the first to actually install a TC VC so you know more about it than anyone else. If I had known a year ago that all I had to do was stack some washers under the coil hold-down I probably would have bought a TC VC instead of waiting for a used XB VC to become available.
14.12 @ 97.6 mph
Old 05-29-2011, 04:57 AM   #12
r2d2michael
r2d2michael 24/M
did not know i was the first? and sorry to thread jack lol
Old 05-29-2011, 05:01 PM   #13
eight08customs
Sponsor
eight08customs's Avatar
eight08customs 14/M
Forjworks
Send a message via AIM to eight08customs Send a message via Yahoo to eight08customs
i had the TC valve cover on my for over 4 years! did the swap when i first got my car becuase had oe sitting around and i already polished it out..
I didnt use any shims what so ever. but yet its a little different.. that why the coilpack cover worked on my car.. coil packs fit fine.. the only spacer that i used was to space up the coil pack cover to clear the top of coil packs..
the differance is between the 2 is the XB coil pack sits actuall higher.. becuase we cant use our coilpack covers on the xb valve covers becuase the coil pack cover will sit to high and a larger spacer has to be used and it looks all weired have a huge gap
I had an issue with inermitent miss and the check eng and traction controll lights went on and after a while went off... I hooked my scanner to it and it said coil pack 1 no good.. so what i did was unplug and plug back in to make sure. the engine code was cleared and ran awsome for while than the same problem came back. but this time it never went away.. so hooked the scanner up again and same thing. so i coilpack one.. i take it out a look at it .. and say to myself it its really the coil pack that went bad if i swapped it out with number 4 i should get the same code but telling me number 4 coil pack is bad. low and behold code was cleared again and car ran fine till today.. this was about 5 months ago.. and car been good ever sence.
I heard about the waire harnees issue and i was trying to avoid it.. and so far so good. i really done know maybe it maybe becuase I already had the TC valve cover? IS swapping out for a TC vavle cover really the answer to this? its hard to say.. Allt hose coil pack the dealerships are changing.. are they just changing out the coil pack just because the sanner says its bad? becuase i was ready to do the same and why would when i swapped them out withthe good one.. it ran fine? Im a ASE mech.. and sometime i question those toyota mechs.. Lucky i have the tools to do the scanning and i can try to determine before i decide to maybe take it in or just fix it my self. but some times i think its maybe a connection issue on the plug that plugs to the coilpack.
HypnoticTealMica .. if if you have acces to a scanner.. i would try to what i have been doing.. just swap it out and see if the code go away. and see if the car runs fine..
http://www.scionlife.com/forums/show...oil+pack+cover
eight08customs is offline   Reply With Quote
Old 05-29-2011, 05:39 PM   #14
ScionFred
ScionFred's Avatar
ScionFred 54/M
The Toyota part numbers for the relevant 2AZ-FE valve covers are:
08-11 XB: 11201-0H060
05-06 TC: 11201-28014 (05/2004 - 10/2005)
06-10 TC: 11201-28031 (11/2005 - )
Eight08customs, do you recall what year TC your VC was from? When you tightened the coils down, did you fully tighten the bolts or just snug them down leaving a small gap between coil and VC? How about you r2d2michael?
Depending on how much taller the XB coils are relative to the TC VC hold-down risers, it would be easy to damage a coil without using spacers on the hold-down bolts. Maybe one of the TC VC's is closer to the XB VC than the other?
14.12 @ 97.6 mph
Old 05-29-2011, 06:03 PM   #15
r2d2michael
r2d2michael 24/M
the first time i tightened them all the way down. so they broke i think lol. the second time i left a gap but they were still sung. then i put in spacers.
Old 05-30-2011, 08:21 AM   #16
eight08customs
Sponsor
eight08customs 14/M
Forjworks
they fit like normal.. I have ne clue to what year TC that valve cover was from.. I got it for free from a freind.. all i know it was all smoothed so was easier to polish out.
next time im under the hood ill go check .. never took notice to anything like what you guys are saying about the shims
Old 05-30-2011, 08:32 AM   #17
r2d2michael
r2d2michael 24/M
there was a certanly a gap on mine
Old 05-30-2011, 05:37 PM   #18
ScionFred
ScionFred's Avatar
ScionFred 54/M
Thanks guys. It seems like one of the TC VC's can be used without shimming the coil packs while the other requires shims. I haven't had a chance to compare them directly but others have and commented on how the XB coil packs sit higher relative to the coil hold-down risers on the TC VC. If r2d2michael's VC is from a 07 TC then presumably eight08custom's VC is off a 05-06 TC and is a better fit for the XB.
14.12 @ 97.6 mph
Old 06-01-2011, 11:24 PM   #19
HypnoticTealMica
I guess my main concern is; are any of you experiencing multiple coil failures like I am? Or is my particular car just burning them up?
Anyone know anything specific about the TSB on the coils?
I've heard it is several pages long.
I'd like to gather as much info possible and want to try being reasonable with the dealer before I call Toyota.
I don't have any test equipment to read Scion codes.
Can you place a volt meter on both ends of a coil to determine if it is bad?
My other question is why are coils not considered part of the engine covered warranty? They are not a service item that wears out. I've never had a coil fail on other cars I've owned.
r2d2michael, did your dealer just consider your coils were no good and replaced them under the TSB? Did they do this since your car was still under warranty?
Old 06-02-2011, 03:58 AM   #20
r2d2michael
r2d2michael 24/M
you can get a scanner for under 60 bucks at sears. it can read/clear codes. the dealer said the coils were under warrnty. im at 32k i gave them the tsb to consider when i brought my car in. not complty sure if it was the same promblem. i probly broke them myself
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2005, 268778, action10030353, bad, code, engine, fix, ignition, nhtsa, p0351, relay, scion, tsb, tsb268778, xa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
