2006 XB suffers from detonation at 1600 to 1900 RPM's
so I have about 50K on my 06 XB. It suffers from a lot of engine detonation at the 1600-1900 RPM range when on light throttle. it seems to get worse as the air temps warm up. it's still noticeable when the engine is at operating temperature.
I sound like a VW beetle when i start to drive away from a stop light.
any ideas? or things I should ask the dealership to look at?
That is odd. I believe the timing is computer controlled on these, but if you've messed with the timing belt.. I suppose it could be off. Definitely would take it to the dealership..
Same problem here on my '05, started soon after dealer replaced cam sensor under warranty, either they messed something up or it's the knock sensor. Too late to take back to the dealer as it only started when the weather started to warm up.
Switch to premium gas to see if it makes any difference. Take a look at the spark plugs, if it's time to change try a step colder. Run a can of good FI cleaner through the tank.
Best way to see what's happening is to connect the scanner and monitor outputs from MAF, TPS, Knock, O2 sensors and timing advance, but that will have to be done by the shop.
I've got to get it to the shop soon but it might be a few more weeks.
I had a similar situation. I was using the Bosch IR fusion plugs. It didn't hit me for little while that the two coincided. After checking everything else, I went back to the stock plugs and the problem disappeared immediately.
The cheapy stock plugs really do seem to make this engine happy.
javio24
Aug 13, 2015 05:27 PM
