Tuning mrd-m501 amp/diamond audio d6 sub..
Old Mar 17, 2005 | 11:44 PM
tbone587's Avatar
Default Tuning mrd-m501 amp/diamond audio d6 sub..
I got everything installed and it sounds good, but there is so many options to mess with that im sure tunes it and what not.. Also im not sure why this is, but as i turn the music up the voltage meter on the amp goes from 12v to like 13ish and it goes on and off, but the sub keeps playing. I was thinking it was the ground, but if that was the case, i think that it would just shut off and the sub would be turning on and off as well..
Old Mar 18, 2005 | 12:13 AM
chipzxb's Avatar
How did you wire up your subs? Aftermarket deck or stock one?
Old Mar 18, 2005 | 12:27 AM
tbone587's Avatar
aftermarket alpine 9831
Old Mar 18, 2005 | 02:19 AM
chipzxb's Avatar
How about the wiring of the subs?
Old Mar 18, 2005 | 03:19 AM
tbone587's Avatar
they are wired in parallel to get 2 ohm load. all i need to know is which settings to put on
Old Mar 18, 2005 | 01:30 PM
tbone587's Avatar
Default wtf..
im kinda angry now... last night everything was booming, this morning for some reason the sub amp turned on, but the sub was producing no noise.. maybe i changed a setting last night before i turned off my car, but im confused/
Old Mar 18, 2005 | 06:05 PM
chipzxb's Avatar
What settings are you wanting to know about?
Old Mar 19, 2005 | 12:37 AM
ugly_duck's Avatar
read the manual, go to www.alpine.com
Old Mar 19, 2005 | 01:40 AM
tbone587's Avatar
sometimes u guys are helpful sometimes u guys arent... ugly duck, i have looked at the manual, and i have the actual manual, they dont tell u what each setting means, they just tell u how to access/change them.. I got it all working again, but i still would like to fine tune all the audio. doesnt seem like im gonna get help here
Old Mar 19, 2005 | 04:21 AM
chipzxb's Avatar
Need to know what you need tuned first there buddy. You can't just say help me tune this.
Old Mar 20, 2005 | 05:10 PM
tbone587's Avatar
i want to tune the sub.. There is options on the sub amp like im not sure what the lpf should be set at, slope, etc..
Old Mar 21, 2005 | 12:01 AM
LavaBox_v1's Avatar
Do you bass or sound quality ... I have the 9835 head unit and the MRD-M501 but I have mine set up for sound quality ... I sat in my drive way for about 20-30min messing with the setting on the head unit and the amp till I got it to the way I like it ... Remember what someone else likes you may not like ... Also I am unsing an Alpine 10" Type-X sub, so my setting will be different then yours because we have different subs ... just keeping adjusting it till you find a setting you like ... You can also call Alpine Tech Support and they can help you with the settings ... I called them a few times tring to tweak my system ...
Old Mar 21, 2005 | 01:47 AM
ugly_duck's Avatar
My apologies, i didnt mean to be unhelpful, however perhaps you should be more specific. What i did mith my 501 i went to my local trusty stereo shop and asked the help of some one smarter than me. But what do you want to accomplish? answer that and you may get a better answer, just a thought.
Old Mar 21, 2005 | 02:50 AM
ScionRI's Avatar
he wants to know how to set his gains correctly, how to set his low pass filter, his subsonic, his phase, electronic-alpineampbruhaha etc.
Old Mar 21, 2005 | 03:31 AM
ugly_duck's Avatar
^^^^i gather that much^^^^
however for the proper advice to be given we must know what he is hoping to accomplish. Just ahint: There are two different settings for pure bass and sq.
SO WHAT DO YOU WANT BASS OR SQ???????
Old Mar 21, 2005 | 10:45 PM
tbone587's Avatar
i would like sound quality if possible, but i still want it to be somewhat loud!
Old Mar 22, 2005 | 12:40 AM
ScionRI's Avatar
alright set your low pass filter at 80hz and xover your mids (if you've got an aftermarket deck that will, or an amp for the components/stock speakers) at 80 hz as well.
Gains should be set appropriately, which means figuring the output of the amp preouts on the back of the deck and matching the gain with that.
subsonic should be turned to 20hz since you've got a sealed box and you wont hear anything below 20 anyways.
that should just about do it i think. ask about anything else. i'm not familiar with your amp so you'll have to ask someone else.
Old Mar 22, 2005 | 02:23 AM
ugly_duck's Avatar
try 80 or 100 in the low pass filter.
there is a neat feature in the manual about setting the input of the deck to match the amp. its the first thing in the manual before the settings. I have a present for you that i found on the alpine site. Whats your e mail.
If you want you can pm me. Its a word doc.
Old Mar 22, 2005 | 02:42 AM
ScionRI's Avatar
80 keeps the imaging up front, doesn't pull the sound to the trunk or hatch.
Old Mar 22, 2005 | 02:51 PM
LavaBox_v1's Avatar
You want to set it at 80hz ... that is what I have my mrd-m501 set at ... Thats the only setting I can remember off the top of my head ... Also what headunit do you have ... Alot of your tunning will be comming from the headunit ... My 9835 has built in crossover for Front, Rear, Sub and a full EQ most of the sound quality comes from tweaking thoes ... the amp is just to fine tune a little more ... If you have a good headunit with crossover and eq you will want to adjust that first and then adjust the amp.
