GT SPEC rear strut bar
Old Mar 20, 2005 | 08:07 AM
sponge_man69's Avatar
Default GT SPEC rear strut bar
this have any benefit in handling???
Old Mar 20, 2005 | 09:04 AM
DarkBoxJr's Avatar
Probably not, since it mounts to the strut mounting and not the entire tower.
Old Mar 20, 2005 | 11:52 AM
It barely does anything , yes it helps stiffen the rear , but it barely does so. not worth the exorbinate price , try the ebay one both have the exact same end results just a huge price difference.
Old Mar 20, 2005 | 06:36 PM
DGTLLVR's Avatar
Well... seeing as how there aren't rear struts on the car. I'd have to say it does zero for handling and is +1 for ricerness. If you buy a rear strut bar for an xA or xB you are a complete idiot. Lay on your back and look under your car... Do you see a strut? No. You see a swing arm that needs no stiffening. When they make a bolt in rear swing arm kit that makes it stiffer, you might consider that, but until then, leave the ricer stuff alone.[/url]
Old Mar 21, 2005 | 01:27 AM
whats with the attitude??? sorry for not been a genius like u
Old Mar 21, 2005 | 01:54 AM
dgHotLava's Avatar
actually if you had looked...you will see shocks in there.
what is a strut? a shock plus spring...
swing arm, solid axle or torsion beam does not make a diff to the top of the strut / shock. do you complain about people using bars up front...
airmankevin1
Feb 14, 2018 01:23 PM
killahXB2
Mar 27, 2015 10:45 AM
xa007xa
Feb 26, 2015 02:12 AM
xa007xa
Feb 22, 2015 02:56 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
