Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge
Register Forgot Password?
Reply
Old 07-25-2011, 01:58 PM   #1
Pauly-FL
Pauly-FL's Avatar
Pauly-FL 49/M
Default OEM Battery
I was just curious - my RS1 is still running with the OEM Panasonic battery. Anyone else see this kind of longevity?
RS 1.0 # 1495 First RS in Broward County!
Pauly-FL is offline   Reply With Quote
Old 07-25-2011, 02:01 PM   #2
TeeCizzle
TeeCizzle's Avatar
TeeCizzle 52/M
i have a 06...still on my Original too!
TeeCizzle is offline   Reply With Quote
Old 07-25-2011, 02:18 PM   #3
usafscion
usafscion's Avatar
usafscion 31/M
Andre De Lira
The weather has a lot to do with the battery life longevity...cold weather kills the battery due to freezing the water(acid) in the battery compartments..
usafscion is offline   Reply With Quote
Old 07-25-2011, 04:41 PM   #4
trdscion
trdscion's Avatar
trdscion 29/M
twitter.com/merrilljoe jedichimps
my '05 is on it's first but I think it's on it's way out. Trying to find an inexpensive replacement.
Flickr | SarapBuhay
FS: OEM fogs + custom VRD grill | FS: BNIB ReplayXD 1080p | FS: '05 headlights w/ 4300 Lexus HID | FS: tC1 Factory Sub
trdscion is offline   Reply With Quote
Old 07-25-2011, 05:50 PM   #5
MeatRocket
MeatRocket's Avatar
MeatRocket 26/M
Send a message via AIM to MeatRocket
2006 tc with 53,400 and still using the original.
MeatRocket is offline   Reply With Quote
Old 07-25-2011, 07:19 PM   #6
trdscion
trdscion's Avatar
trdscion 29/M
^^ 115K
Flickr | SarapBuhay
Old 07-25-2011, 11:04 PM   #7
05sciko
05sciko 26
05 and run a 1100 watt amp daily!
05sciko is offline   Reply With Quote
Old 07-26-2011, 01:32 PM   #8
Pauly-FL
Pauly-FL's Avatar
Pauly-FL 49/M
Quote:
I suppose so. When we get into the low 60s folks around here break out their parkas!
This battery is lasting longer than the original GoodYear tires! I only got 17,000 miles out of them
Old 07-28-2011, 01:59 PM   #9
Improbcat
Improbcat 35/M
Send a message via AIM to Improbcat
I'm at 164K on my '04 with the original battery. And this was after it was run down to 0 volts by an idiot bodyshop two years ago. Every fall I think I should replace it, but since it didn't even crank slow when we had single digit temps I now want to see how long it will go.
Think inside the Box!
Improbcat is offline   Reply With Quote
Old 07-31-2011, 10:31 AM   #10
Davestoaster
Davestoaster's Avatar
Davestoaster 113/M
Actually, the opposite is true.
Heat is the destroyer of your cars battery caused by the evaporation of the electrolyte. This causes less chemical reaction and less power to be available in the battery, THEN you go into winter, and the cold temps cause the chemical reaction a weakened battery to slow down. That's why they die in the winter.
The moral of the story: Be sure and check the battery water level. If the tops of your plates are showing....... you're done. And if you have one, maybe put a 10 amp charger on it for about an hour once a year or so.
BTW, still have my original battery here since new.
Dave
2005 BCP xB
2011 Lexus HS 250h
Davestoaster is offline   Reply With Quote
Old 07-31-2011, 05:33 PM   #11
bearcave
Scion Apocalypse
bearcave's Avatar
bearcave 71/M
This was the most accurate post. Also, the Panasonic is a 'sealed' battery to which you can not add water, so once the water level drops below the minimum line, you need to replace it. Mine crapped out on me at 52K miles.
Google+
bearcave is offline   Reply With Quote
Old 08-01-2011, 03:11 PM   #12
pooder
pooder's Avatar
pooder 59/M
Quote:
Stubby ('06 Camo) is still on his original battery.
He lives a sheltered life, though; his garage is (relatively) cool in summer and warm in winter, and he's only in weather extremes in the work parking lot during the day, and that's primarily in the winter 'cause I commute on two wheels whenever I can during the summer months.
"What do *you* care what other people think?" -Arline Feynman
pooder is offline   Reply With Quote
Old 08-02-2011, 12:32 PM   #13
7red7
7red7's Avatar
7red7 34/M
Send a message via AIM to 7red7 Send a message via Yahoo to 7red7
My RS1 is still running the original battery as well. My windows are just now beginning to go up a bit slower than they should, and running the radio for about two hours (without the engine on to charge) required a jump start. I think it's about time to finally replace it.
"For every minute I spend unhappy, thats one minute of my life I've wasted...I refuse to spend time wasting my life."
_________________________________
I used to own Hot Lava RS1 # 0846 of 2100...Now I own #1661!!!
Fuscion Asst. Secretary 2012
7red7 is offline   Reply With Quote
Old 08-03-2011, 03:37 AM   #14
Bobielon
Bobielon 27/M
hmm, I have 3 years and 73k on mine, no issues yet and I live in Montana.
Bobielon is offline   Reply With Quote
Old 08-12-2011, 11:53 PM   #15
rayster
rayster 28
06 5 years and still going strong
rayster is offline   Reply With Quote
Old 08-12-2011, 11:54 PM   #16
myselfdotcom
myselfdotcom 34/M
Send a message via MSN to myselfdotcom
I finally replaced my battery, 06 scion, 88k
myselfdotcom is offline   Reply With Quote
Old 10-19-2011, 05:20 PM   #17
pollock3s
pollock3s's Avatar
pollock3s 48/M
My RS4 ( 70,000 miles) still has it's original battery. Watch it'll poop out tomorrow.
pollock3s is offline   Reply With Quote
Old 10-20-2011, 10:47 AM   #18
AP
AP's Avatar
AP 38/M
Replaced OEM battery at around 125K. 2006 xB idles much better.
Los Angeles CA.
2006 xB 3.0 Series.
AP is offline   Reply With Quote
Old 10-20-2011, 12:44 PM   #19
jct
jct's Avatar
jct 73/M
i replaced my battery after five years just to be on the safe side
i replaced my airbags with confetti
ಠ_ರೃ
jct is offline   Reply With Quote
Old 10-21-2011, 04:21 AM   #20
bbszero
bbszero's Avatar
bbszero 40/M
OEM's just went out in both 05's within 2 weeks of each other.
Hub Spacers * Camber * Air Ride * Clazzio covers * Grip Royal* D2 coilovers* and more!
COMPLETE AIR RIDE SYSTEM for 1425.00!
http://2zero6factory.com/
2zero6 Factory gear! http://2zero6factory.spreadshirt.com/
bbszero is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2005, 2006, battery, factory, life, oem, panasonic, replacement, scion, scionlife, start, stock, tc, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
