215/40/19 on Xb??
Old Mar 21, 2005 | 12:05 AM
scioning's Avatar
Default 215/40/19 on Xb??
I have searched and read and just want to be sure!
I have purchased 19x8 +45mm offset wheels. I have also ordered a set of shims from van. I am wanting to put 215/40/19 or 225/40/19 tires with a 2" lowered springs. Does anyone for see a problem with turning or anything else. All help would be appreciatied.
I'm sure the 215/35/19 will be fine but would like a little more cushion on the rim if possible.
Old Mar 21, 2005 | 12:55 AM
sexyscionlover's Avatar
damn! i dont know if you'll be able to run the inner plastic fenders. i would honestly go with 35 series to avoid a lot of problems. im sure its been done but i think its gonna be hard.
Old Mar 21, 2005 | 12:54 PM
Shoof's Avatar
60 mph on your speedo will really be 55 mph. You're trying to put a tire that is almost 7 inches "rounder" on circumference.
Old Mar 24, 2005 | 01:34 AM
DTurnbull's Avatar
You got that backwards. Actually, if you're going 60 mph on your speedo, your actual speed is 65.13.
Go here:http://www.discounttiredirect.com/di...foTireMath.jsp
Old Mar 24, 2005 | 11:33 AM
TREX212426's Avatar
i have 205/40/ 17's is this going to be a problem heading up long distance
Old Mar 24, 2005 | 01:16 PM
Munch's Avatar
I have 225-35-19 and they work fine. THe 225-40-19 Is not gonna work at all without constant rubbing.
