Rear caliper issue
Old 08-11-2011, 12:17 AM
nizzle74's Avatar
Default Rear caliper issue
Had to change rear pads and the guide pins both L/R seem to be frozen. I tried PB Blaster, Heat, and a punch neither side seems to free up. For the time being I just changed the pad knowing the inside shoe will wear prematurely. I want to know if anyone either knows a way to successfully free the pins or a detailed how to on changing out the rear calipers, specifically how to deal with the parking brake assembly on the caliper. Do I need a special tools to deal with the parking brake part of the change out? I looked and couldn't find a thread on it. One with pics would be great.
nizzle74 is offline
Old 08-11-2011, 02:12 AM
Lil_Deuce_tCoupe's Avatar
Repair manual is here:
https://www.scionlife.com/tech/manual/?manual=tc05_0001
Lil_Deuce_tCoupe is offline
Old 08-11-2011, 02:38 AM
Zsanz's Avatar
pb blaster again and just throw pliers on it and squeeze the pliers with one hand trying to rotate it, and then with the other hand slam it with a hammer, perpendicular to each other, works for me
Zsanz is offline
Old 08-12-2011, 12:42 AM
nizzle74's Avatar
I thought of the pliers too but in the end i thought it would scratch the S*$t out of it and would make it worse in the long term. I guess at this point I COULD try that before I replace em. I ended up tearing the rubber boots off. IF I did get them free I think I will be constantly "F"ing with them. Thanks for the replys!!
Checked out the repair manual link.... Exactly what I needed THANKS!!!
nizzle74 is offline
Old 08-14-2011, 10:01 PM
StreetSweeper's Avatar
i hadda buy new ones cause mine both siezed and i got them at fishers for like 65 a piece
StreetSweeper is offline
evolving_machine
10-21-2023 01:16 PM
Squishface
09-15-2015 06:51 AM
TheTripleC
01-04-2015 06:46 PM
fluxingnation
12-26-2014 04:28 PM
Slopoke21m
54
04-23-2007 12:25 AM
Quick Reply: Rear caliper issue
