How do you get rid of fog in your headlights???
Old Mar 21, 2005 | 07:13 PM
blackedoutxb's Avatar
Default How do you get rid of fog in your headlights???
I have a lot of fog in my driver side headlight and i was wondering if you guys can help me out? I tried to seal it with seal all which i purchased from discount auto and it still doesnt work . If you have any suggestions please help me out!!
Thank you in advence,
blackedoutxb
Old Mar 21, 2005 | 08:28 PM
bBsactoguy's Avatar
Hrmmm, Im not sure.
But to get rid of some glare I use meguiar's PLASTIC X. Makes it clean. But in the cold morning there's that haze. : (
My friends also recomended 3M de-oxidizer. Said you can find it at Kragen or any auto parts store, but I never seen it there.
Old Mar 21, 2005 | 08:40 PM
Yeah it totally kills the look of the car. I wanna take pictures soon but i never can becuase the headlight is fogged. Thanks for your input bBsactoguy.
Old Mar 21, 2005 | 08:52 PM
pdrizzle's Avatar
DeepSouth Scions
Try replacing or reinforcing the rubber washer/grommit where the bulb connects to the head light housing.
Old Mar 21, 2005 | 09:02 PM
M-Flo's Avatar
Use a hair dryer
Remove the bulb for ventilation and use a hairdryer to heat up the headlight housing. Soon the water will evaporate and escape out of the hole.
It's not a permanent fix, but it works nonetheless :D
Old Mar 21, 2005 | 10:12 PM
ssdm7683's Avatar
Take it to your dealer and have it replaced!
Old Mar 21, 2005 | 10:21 PM
Romanova's Avatar
No kidding! This should not happen on your car. Make THEM fix it. They might have a TSB or special notice on it.
If you have ANY problems with your car and it is under factory warranty, make the dealership fix it.
Old Mar 21, 2005 | 11:56 PM
BAGGED_XB's Avatar
Are you still running factory bulbs? If you are, then take it to the dealer for replacement. There may be a hairline crack in the sealant from the light housing to the lens. If not, make sure the rubber gasket around the bulb is snug. If you take it back with aftermarket bulbs in it, then the dealer will blame the fogging on the bulbs. I've been down that road before, so take my word on it, if they can find a way to get out of replacing it based on something you did, then they won't fix it. (not under warranty, any way)
Old Mar 22, 2005 | 12:38 AM
Max2k's Avatar
Take the bulb out and hairdryer it.
Old Mar 22, 2005 | 12:35 PM
Shoof's Avatar
Turn the low and highbeams on and let it sit like that for a bit, the fogginess should go away, for now..
bluemex
Oct 14, 2015 03:29 PM
carid
Jun 18, 2015 01:20 PM
carid
Jan 8, 2015 11:33 AM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
umnitza
Dec 1, 2014 06:26 PM
