bumpstops for trd springs
Old Mar 23, 2005 | 05:04 PM
xpuhlode's Avatar
Default bumpstops for trd springs
I've done multiple searches already but can't seem to find the answer. Does anyone know the scion-recommended amount to cut the bumpstops by? I know someone on this forum said that they cut them in half, but i'm wondering if there is a more specific amount.
Tx.
Old Mar 23, 2005 | 05:18 PM
lebshiff21's Avatar
I didn't cut mine...
Old Mar 23, 2005 | 06:42 PM
yamaha16bw's Avatar
^^^^ Same here.
Old Mar 23, 2005 | 06:51 PM
stick_1NZ's Avatar
I cut mine 1" but i'm using Tom's.
Old Mar 23, 2005 | 09:14 PM
garfull's Avatar
i cut about one notch worth. about the difference in heights of the springs if i remember corectly
Old Mar 23, 2005 | 11:33 PM
ConjunctionJunction's Avatar
cut it by the amount of difference from stock, because you'll need roughly that amount of travel after they're installed. if you dont, its gonna hit the bumper stops and ride poorly
Old Apr 3, 2005 | 06:27 AM
tckurt's Avatar
N.G.S.O.
whats a bumpstop?
Old Apr 3, 2005 | 07:14 AM
hahaitzskippy's Avatar
you dont really need to cut them... IMO
work fine as is
Old Apr 4, 2005 | 06:59 AM
chris0's Avatar
when gabe put mine on he cut off that first notch, seems to be the right amount.
chris
Old Apr 6, 2005 | 12:52 AM
tCtech's Avatar
Originally Posted by tckurt
whats a bumpstop?
it goes on the strut underneath the strut top. it's a foamish material that is shaped similar to a small ice cream cone. normal, not waffle cone.
and scion has no reccomendation for cutting the bumpstop. there is no directions. trd sells the springs, so it isn't in our system of accessories. no manual, no how to.
any cut to your stops is based on your own will/whims of the tech putting them in.
Old Apr 6, 2005 | 02:13 AM
chipmOnk's Avatar
what exactly does it do?
Old Apr 6, 2005 | 07:46 AM
chris0's Avatar
occaisonally may go over a bump at a speed that will push the limits of your struts & springs, causing you to "bottom out." if you didn't have bump stops you'd be slamming metal on metal. with bump stops, when you bottom out, you're slamming metal on foamish material. this foamish material is a certain height. taller bump stops allow for less travel in your struts before you bottom out. trimming the bump stops will allow for more travel.
I hope that helps.
chris
Old Apr 6, 2005 | 03:55 PM
JSVH's Avatar
I cut the front bump stops about an 1" and left the rear alone when I installed my springs.
Old Apr 7, 2005 | 02:34 AM
chipmOnk's Avatar
I hope that helps.
chris
Ah I see, thanks. I saw tCtech's post, but I didn't really understand what he meant.
DJ_FroZone
25
May 30, 2019 07:17 PM
danielv
Aug 26, 2015 07:14 PM
Scion0814
Feb 12, 2015 01:41 AM
JPuehl
Jan 10, 2015 01:01 AM
minter66
Dec 15, 2014 01:45 PM
