Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 10-13-2011, 03:37 AM   #1
sci0n-tc
sci0n-tc's Avatar
sci0n-tc 26/M
Jynxs86
Default Calling all supercharged Tc's!
Calling all supercharged tc's. I had recently installed a s/c on my car last weekend and was told I can make the BOV/BBV atmospheric "louder". So today I took off the re-circulation hose off and plugged up the bov inlet of the supercharger. Started the car, and immediately it didn't idle correctly and my AFR's were way rich from 10.1 and below. Put everything back to normal and it ran just fine. So can I not use a hks bbv to atmospheric? or am I missing a vacuum issue??
sci0n-tc is offline   Reply With Quote
Old 10-13-2011, 04:32 PM   #2
gompka
gompka 28/M
Send a message via AIM to gompka
I had mine setup as atmospheric and it ran fine, only ran rich between shifts, which added a nice gunshot style backfire every now and then.
Quote:
Supercharger information: Tcsuperchargers
Custom supercharger shafts: Custom Shafts
Grease fitting information Grease fitting
gompka is offline   Reply With Quote
Old 10-13-2011, 06:02 PM   #3
SoccerBoy_AP
SoccerBoy_AP's Avatar
SoccerBoy_AP 31/M
Send a message via ICQ to SoccerBoy_AP Send a message via MSN to SoccerBoy_AP
I've never tried fully atmospheric with my hybrid; only fully recirc and partial.
Did everything go ok with the ECU flash from Mountain State Toyota?
2006 - Scion tC - TRD S/C
55mm Pulley @ ~10psi
(outdated dyno @ 65mm)
207hp/188tq @ 7.7psi
SoccerBoy_AP is offline   Reply With Quote
Old 10-13-2011, 09:47 PM   #4
sci0n-tc
sci0n-tc's Avatar
sci0n-tc 26/M
Jynxs86
Not really! I wasted 1 hour there, come to find out they don't have the sim cards needed to flash the ECU. The service tech told me no more were produced after they discontinued the s/c. So I found a member on here selling a flashed ECU cheaper than what the dealer was going to charge. Car pulls good! but like you said even with the 9.5 pulley it only gets to 5 maybe 6 psi, not much but it gives the beast some pep!
Old 01-30-2012, 08:54 AM   #5
silver_jazzy
silver_jazzy 26/M
i just installed a turbosmart dual port bov and been havving idling issues to the point where the engine would stall. i have the spring tightened all the way. any tips?
silver_jazzy is offline   Reply With Quote
Old 01-30-2012, 09:18 AM   #6
DeAnzaJig
DeAnzaJig's Avatar
DeAnzaJig 22/M
well make sure you cap off the RECIRC tube (not the tube under boost), and check for vacuum/boost leaks. then report back.
Craigslist Add: Never launched or driven hard
DeAnzaJig is offline   Reply With Quote
Old 01-30-2012, 06:28 PM   #7
AZGuy
AZGuy's Avatar
AZGuy 34/M
Quote:
I have the dual port as well, I had to tighten it down pretty far to get it to idle and not have the random die when throttle was removed while running hybrid mode. Once I got this dialed in I didn't like how my AFR was all over the place at partial throttle on the freeway where it would transition to atmo. I ended up putting it into full recirculation mode but will probably mess around with the hybrid mode again some more.
TRD Supercharger, NST 12psi pulley (see 14psi), AEM Meth injection, Unichip tuned
Magnaflow exhaust, TRD rear sway bar
H techs, Super 7s, Custom badgeless grill, Leather interior, Paint matched interior pieces
AZGuy is offline   Reply With Quote
Old 01-30-2012, 06:51 PM   #8
Syldrin
Syldrin's Avatar
Syldrin 27/M
Syldrin
Send a message via AIM to Syldrin Send a message via MSN to Syldrin
why don't you guys try the synapse BPV? i hear good things about it and you can make it a 50/50 hybrid
Dezod Alpha series and more to come
Syldrin is offline   Reply With Quote
Old 01-30-2012, 07:40 PM   #9
silver_jazzy
silver_jazzy 26/M
Quote:
you think a proper tune would fix this? btw are you running any piggyback or any engine management?
Old 01-31-2012, 02:01 AM   #10
AZGuy
AZGuy's Avatar
AZGuy 34/M
Yes I'm running unichip tuned with the 12psi pulley.
Old 01-31-2012, 02:40 AM   #11
JDMTC5
JDMTC5's Avatar
JDMTC5 27/M
What kind of BPV or BOV would u guys recommend? I just installed my kit 2 weeks ago.
FW21
JDMTC5 is offline   Reply With Quote
Old 01-31-2012, 09:20 AM   #12
silver_jazzy
silver_jazzy 26/M
where do you live? you actually found a shop that tunes unichip? im currently on trd reflash tune and my unichip is sittin in my room just waiting for me to find a tuner. lol.
oh and my 07+ supercharger's pulley bolt seems to be locked with this flower shaped bolt. how do you remove that bolt? planning on just keeping the pulley stock to prolong supercharger life but you never know. i might go 9.5 lbs later on.
Old 01-31-2012, 01:43 PM   #13
AZGuy
AZGuy's Avatar
AZGuy 34/M
I have it tuned in Phoenix, AZ. Do some searching on here on how to remove the bolt, does take some work. If you live in AZ I do have a key to take it off the bolt.
Old 01-31-2012, 08:40 PM   #14
silver_jazzy
silver_jazzy 26/M
where did you get the key from? toyota? do you have a link for the thread that talks about removing it?
Old 01-31-2012, 10:28 PM   #15
AZGuy
AZGuy's Avatar
AZGuy 34/M
I made the key which is also in this thread and they also discuss how they removed theirs.
http://www.scionlife.com/forums/show...ighlight=azguy
Old 02-01-2012, 08:53 AM   #16
silver_jazzy
silver_jazzy 26/M
thanks azguy. youre the man.
Old 02-01-2012, 08:57 AM   #17
silver_jazzy
silver_jazzy 26/M
and if i get the 9.5 lbs pulley do i have to get a shorter belt? do you know what size?
Old 02-01-2012, 09:32 AM   #18
silver_jazzy
silver_jazzy 26/M
btw i have a dayco 5070900 belt on right now. its effective length is 90 inches and it sits pretty tight around the pulleys. how much smaller is the 9.5 lb nst pulley? if its smaller by just a tad bit then maybe the belt i have on will do since its sitting kind tight right now?
Old 02-01-2012, 12:41 PM   #19
AZGuy
AZGuy's Avatar
AZGuy 34/M
You will need a new belt.
Old 02-01-2012, 08:45 PM   #20
silver_jazzy
silver_jazzy 26/M
do you know thed length of the belt?
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2012, 55mm, bov, ca, calibrations, diego, dyno, install, mess, reflash, san, sci0n, scion, shops, supercharged, supercharger, tc, trd, tune, unichip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
