2004-2006.5 [NCP61]
What is going wrong with my wittle car? v.xA
Old Nov 27, 2011 | 08:48 AM
Dev's Avatar
Dev
Default What is going wrong with my wittle car? v.xA
Help with diagnostics would be great.
car is a 2006.5 xA, automatic trans w/ 55000 miles
symptoms are :
loss of MPG
loss of ~1/2 a volt in the electrics
possible slight increase of vibration when stopped & in gear
one time, when the car was still cold after startup, I got to the first stopsign in front of my house and the 'o/d off' trans override light came on (on it's own)
no MIL or CEL thrown
Old Nov 27, 2011 | 02:50 PM
jpn6438's Avatar
Have you done any electrical work to the cars (h.i.d., led bulb swap, etc.)?
Old Nov 27, 2011 | 05:55 PM
Dev's Avatar
Dev
nope
I do have an amplifier installed that draws a decent amount of juice. Also have a scan guage 2 and monitor the voltage realtime.
Old Nov 27, 2011 | 07:59 PM
jpn6438's Avatar
A friend lost some mpg due to changing out her plugs. She have an 05. Did h.i.d. on mine (05 also) and my tech does read right sometime but drive normal. Change out to some better quality ballast and issue stop.
Old Nov 28, 2011 | 07:17 PM
JIMXB's Avatar
symptoms are :
loss of MPG
Its' hard to diagnosis by the info/history that you are giving, all we can do is guess as there could be many variables
Are u sure you did not hit your OD in error LOL as it only happen 1x
Loss of voltage could be your amp/radio/headlights etc. when all on drawing more amperage than your stock 80 amp alternator is putting out.
Loss of MPG/vibration:
are your tires properly inflated,
Did you try fuel injection cleaner? thru the gas tank or engine
OEM spark plug change to be done every 30K
Coil On Plugs don't have a maintenance interval. Unless there is a problem - cracked insulation, rubber deteriorated, missfire - they should last the life of the vehicle. U can do a coil plug test on the car or a bench test
http://autorepair.about.com/od/troub...est-manual.htm
Have u ever looked at the PCV valve? If the PCV valve is clogged, your car might spit and sputter or even stall while driving.
Old Dec 3, 2011 | 03:13 AM
joey3002's Avatar
OP any update on the suggestions?
Sent from my htc evo using tapatalk
Old Dec 3, 2011 | 11:44 PM
Dev's Avatar
Dev
battery had a bad cell
case closed
Old Dec 4, 2011 | 03:31 AM
joey3002's Avatar
Thanks for update. That's alot for a battery but good to know
Jordly221
Feb 13, 2019 05:29 PM
meowtc
Mar 5, 2015 02:28 AM
2006sciontcva
Scion tC 1G Aero & Exterior
Jan 7, 2015 01:51 PM
carid
Dec 16, 2014 09:53 AM
tC_Normo
Oct 22, 2003 07:20 PM
