Is your Radio/CD equalizer set to xB or xA?
Old Oct 3, 2003 | 01:21 AM
Strader's Avatar
Default Is your Radio/CD equalizer set to xB or xA?
Just found out after getting hold of an instruction manual that the radio/CD has two different equalizer settings, one for the xA and the other for the xB. The radio installer is supposed to correctly set it to your car. In my case it wasn't. I have a xB but the equalizer was set to xA, which is the default.
Changing the setting is simple: just hold the SSP button in until you hear a beep, and then use the volume + and - buttons to change from xA to xB. I haven't had time to check it out but am assuming the setting makes an audible difference.
Old Oct 3, 2003 | 01:35 AM
DibujoB's Avatar
I drive an xB, but to be honest I like the setting on xA better. I usually roll with that.
Old Oct 3, 2003 | 01:37 AM
hatchbox's Avatar
i second that, i set my ssp on "feel"
Old Oct 3, 2003 | 01:49 AM
scionspecialistvegas's Avatar
Default Xa or Xb setting
I also agree Xa and fel seems to sound best in Xb
Old Oct 28, 2006 | 04:58 AM
ignatiusaids0o's Avatar
me too
Old Oct 29, 2006 | 03:05 AM
jct's Avatar
jct
the xA setting sounds so good in my xA hahaha
Old Oct 29, 2006 | 03:27 PM
wagonbldr's Avatar
The Family
Default radio settings
Glad I'm not the only one that thinks the box sounds better set for XA and FEEL. Had a guy with an XA at a local show couldn't understand why his radio sounded so bad. It was set for TC.
Old Oct 29, 2006 | 03:28 PM
sakko's Avatar
Yeah I concur the tC setting blows. xA on xA!
Old Oct 31, 2006 | 03:35 PM
Gamecat's Avatar
hah... yeah i had some work done on my car by the dealership. I assume the disconnected the battery (radio settings were all gone..)
Afterwards I was sure my stereo sounded "weird..." Couldn't really explain it or describe it.. it was just different.
Then while glancing through the manual I cam across the part that talks about the EQ... and fixed the problem.
I was kind of mad... You'd think the scion dealer would know this right? (riiiiiggghhhhttt...)
Old Oct 31, 2006 | 04:35 PM
dagarhart's Avatar
Scionetics
Yes, the tC eq blows, xB is alright, but the xA setting and "feel" are the best for the stock radio.
Old Oct 31, 2006 | 04:38 PM
hotweelz4me's Avatar
Same here, mine was set to tC upon pickup, now stays on xB: seems to deliver more bass
Old Oct 31, 2006 | 04:43 PM
dagarhart's Avatar
Scionetics
You might want to try xA, it sends even more bass.
Old Oct 31, 2006 | 05:01 PM
CHPRBOX8's Avatar
i'm with everybody above i have mine set to xa and on feel best settings on the radio
Old Oct 31, 2006 | 05:10 PM
TheScionicMan's Avatar
I use the xA setting in my xB, but I prefer HEAR over FEEL. FEEL seems to distort at a lower volume than HEAR. But the xA setting seems to spread the music better in the xB space.
I don't have a tC option since they didn't exist when my radio was built.
Old Oct 31, 2006 | 05:16 PM
bgtfc's Avatar
I tried all three settings in my xA. The xA setting seems much louder and better.
Old Nov 1, 2006 | 04:00 PM
kitkit201's Avatar
xA + feel = best for xB
Old Nov 1, 2006 | 10:53 PM
Might have to try the xA sound, I have upgraded the dash speakers with 4.5 Pioneers, and have 2 bazooka subs in the back, so I'll see if xA eq pumps out better bass or not
Old May 7, 2007 | 04:58 AM
SecretAgentMonkey's Avatar
Hmm...when I try xA in my box the speakers crackle/pop a little even at low volumes. I have volume at 15, base at 5, trebble at 3 and balance/fade at 0. Listening to something with heavy base gives me a slight crackle...xB setting is a little more subdued sounding but I don't get that.
Old May 7, 2007 | 06:36 PM
Sunny's Avatar
I get crackle either way. This is the first time I have had factory speakers since I was 15. I have to get rid of them ASAP.
Old May 7, 2007 | 07:28 PM
DriverXa's Avatar
xA, SSP feel, Treble +5, Bass +4. sounds the best to me. Can't wait for my sub to arrive then it should sound even better.
